Jul 19, 2019, 12:08 PM
myflydream's Avatar
Originally Posted by Papsi
Have the SD card connected as seen in the photo.
Nevertheless, it can not save data in the menu. It always appears "Failes to Save"
I use a 64GB SD card. Formatted as a test with NTFS and Fat.
What else can I test?
Plug the TFCard before you power on the AP.
NTFS is not supported.
Use a 32G card to test?
The wiring seems correct.
Jul 19, 2019, 12:27 PM
Papsi's Avatar
TFCard is pluged in before PowerON
I only have 64GB Cards ;-)
Jul 20, 2019, 12:15 PM
Breaker of things...
Save/Load config, and log your flying path with KML files.
Thank you for that info.
How do I use the KML files???
I've not flown mine yet as I have had a very busy time... You know.... Life... Lol.
I guess I will get to grips with it once I start to familiarise myself with it...
Thanks again,...
Jul 20, 2019, 03:16 PM
Mayornikov's Avatar
Good evening. Today I received a new autopilot and have not found a preset for the aircraft MTD. Settings for Crosswind MFD MTD plane correspond to? Also, when setting up autopilot once popped an error Error2 - what does it mean? Thanks for help!
Jul 21, 2019, 01:17 AM
Mayornikov's Avatar
Please tell me, in STB mode, the elevator deviates very little - should it be so? Today I will try to fly around.
Jul 21, 2019, 10:04 AM
Hi Folks,
I've finished installing (physically)
My Crosshair into my flying wing.
I've gone to power up and my throttle goes to about 50% straight away and all of my controls are mixed up.
What is the output order?
I'm running a DTF UHF kit and have it set to
TAER.
I did expect this to work as I swapped the old AP out for this one....
Sent from my H3113 using Tapatalk
Jul 21, 2019, 11:31 AM
Not exactly related to the cross hair but since it was mentioned here anymore updates on the mini Telefly module
Jul 21, 2019, 12:56 PM
Papsi's Avatar
Error found: Only memory cards with max. 32GB supported.
Jul 22, 2019, 12:08 AM
Flying Zayin
Cathay Stray's Avatar
Asking a cook to hurry up doesn't improve food quality
Let the guys do their job in their normal way at their normal pace.
I'd carefully guess late September can be good time for mini TFP to come out. But don't take it as a "controlled leak", it's just my guess.
Correction:
May be before that, in fact. May be as early as before next (not "coming" but "next") weekend!
Jul 22, 2019, 09:39 AM
Hi Guys I'm waiting to see a review of the crossbow AAT. Anyone get their hands on one yet?
Jul 23, 2019, 08:34 AM
I'm also very interested in the mini Telefly...
Jul 23, 2019, 12:19 PM
myflydream's Avatar
Thanks again,...
Drag the KML file into GoogleEarth you will see your flying path.
Jul 23, 2019, 12:23 PM
myflydream's Avatar
News update:
New TeleFlyTiny will be available on our webshop tomorrow (2019/JULY/24th), for a price 25$.
Jul 23, 2019, 12:28 PM
myflydream's Avatar
I remember that there is a limit... and now thank you to point it out: 32GB.
Because it costs too much time to support/test bigger TFCards, so it's not a high-priority task at this moment. At the end of this month, we will do some demonstration flights to show new features of Crosshair/mini Crossbow/mini Crosswind
Jul 23, 2019, 01:07 PM
News update:
I will definately order 2 or 3
New Product MyFlyDream Autopilot control bnn1044 FPV Equipment 8100 Aug 18, 2019 01:39 PM
Discussion MyFlyDream Autopilot: AWESOME! brifa FPV Equipment 33 Sep 07, 2014 04:16 AM
