Jan 19, 2019, 10:59 AM
Motors spin up faster after hard landings.
Iím a bit concerned. When in Acro/Rate mode and I make a rougher landing, for instance if I drop throttle a foot or so off the ground and it lands a little hard the motors start to speed up at idle. Almost to the point where my quad starts moving off the ground a few centimeters.
Anybody have this problem before? And is there anyway to stop it? Iím flying the SPAN F4 AIO Tower from GEPRC. Dshot600.
Jan 20, 2019, 12:42 AM
Can you disarm the quad when that occur? if so, when you arm back again still the problem persists?
Jan 20, 2019, 02:24 AM
If it flies, I can crash it.
rocketsled666's Avatar
Check to be sure you don't have AirMode enabled.
Jan 23, 2019, 11:06 AM
Once I disarm and rearm it goes back to normal idle.
Jan 23, 2019, 11:07 AM
I actually do have air mode on. I been told itís better to use air mode than idle up.
Jan 23, 2019, 03:45 PM
After looking thru the web I guess it’s a normal issue when using air mode. Had no idea but I guess the trick is to disarm right before touchdown. Total noob here.
Jan 23, 2019, 10:54 PM
Yeah. I generally fly to about where I want to land, hover down to relatively close to the landing surface, and then hit DISARM and let it drop.
Jan 24, 2019, 02:42 PM
I disarmed before landing today after each pack and it worked perfect.
I also learned that if you donít disarm before you bellyflop it makes a terrible sound compared to disarming before it hits the ground. Makes it seem like a hit a lot harder than it really did.
Question Changed one ESC, recalibrated, but this Motor now spins up way earlier and faster...? m4v3r Multirotor Drone Electronics 5 Mar 29, 2018 01:28 PM
Help! Variable motor spin up from Tx after calibration Rippernz Beginner Multirotor Drones 22 Jun 05, 2016 09:42 AM
Discussion hubsan x4 after motor replacement, one motor spins up partially on its own help spencer911 Mini Multirotor Drones 8 Feb 15, 2016 01:16 PM
Discussion CC3D - One motor spins up faster! ukaya Multirotor Drone Electronics 2 Dec 03, 2015 04:15 PM
Help! Motor not spin up after upgrade to Cleanflight 1.10 lcc014 Multirotor Drone Electronics 5 Oct 16, 2015 12:42 PM
