This thread is privately moderated by Slider2732, who may elect to delete unwanted replies.
Jan 19, 2019, 01:06 AM
Storm Runner guy
Slider2732's Avatar
Any of the old 2 channel planes to 2.4GHz
Totally forgot to post the upgrades to the Santa Quad airplane firmware!
It's all based on the excellent Silverware code...my idea being to convert the drone TX/RX to be able to fly circa 2010 old classics, with modern 2.4GHz control.
Below are various flight demo's of the different firmwares.
The firmwares themselves are in the attached Zip folder and a HowTo set of instructions is included. Also, what the various code flashes will enable for a specific 'Style' as they're called.
Flashing is the same as for Silverware, however you currently flash works fine.
Included flashing instructions are mainly for Linux users, as that's what I run.
All safety's are still in place, such as throttle off with loss of signal, auto rebind, LVC.
An aircraft will bind at any angle, no need for a level surface.
The gyro is disabled, being that it can interfere with planes that have no dihedral or long wings (ask me how I found that out, as they say).
Range is up to 400ft, shown in the videos, everything is far better without 4 motors buzzing away next to the RX and when the antenna is pointing upward from the board.
Throttle on the left stick, ailerons/rudder/elevator on the right stick.
ITC Starscream conversion - Differential Thrust + ZTT
+ intro to the system:
Raptor vs Raptor - Bird attacks quad powered model airplane (4 min 54 sec)
Ailerons and Elevator:
AilElev - Santa RX (3 min 11 sec)
Elevons:
Santa RX - Elevons (3 min 31 sec)
Rudder:
Hydra rudder ! (2 min 11 sec)
Have fun!
Discussion Does Lightbridge 2.4GHZ interfere with OTHER planes on 2.4GHZ trasher_can Radios 4 Oct 19, 2016 07:58 AM
Discussion Is it possible to use 2.4Ghz 200mW Video with 2.4Ghz Radio on plane if spaced out? coreysnyder04 FPV Equipment 9 Mar 04, 2016 11:48 AM
New Product AeroSky RC Sky Trainer RC Plane w/ Flaps 4 Channel 2.4ghz Ready to Fly 1400mm Wingspa Nitro_Nancy Nitro Planes 0 Feb 26, 2016 07:33 PM
New Product Art Tech AT6 6 Channel Warbird/Trainer RC Plane RTF 2.4Ghz RC Remote Control Radio Nitro_Nancy Nitro Planes 0 Feb 26, 2016 06:12 PM
Discussion FlySky FS-T6 2.4ghz 6 channel system vs. FlySky FS-TH9X 2.4GHz 9 Channel Zeroeffect Multirotor Drone Electronics 3 Apr 29, 2015 08:42 PM
