Jan 16, 2019, 02:56 AM
FrSky-MKT
New Product
FrSky New Arrival - Neuron 40 / 60 / 80 ESC
The FrSky Neuron Series ESC is a professional grade control unit, integrated with built-in telemetry like high-precision current sensor, voltage sensor, motor RPM, power consumption and ESC temperature sensor. Features optional DShot signaling and an adjustable SBEC voltage, that can be changed via LUA script. The Neuron ESC is encased in a CNC aluminum protective shell which also aids in heat dissipation. As with most FrSky products, the Neuron series is completely S.Port compatible, allowing you to use our full line of S.Port Telemetry sensors.
Description: Name: 4.jpg
Description:
SPECIFICATION
● Dimension: 59*33*17mm (LWH)
● Weight: 58g
● LiPo Cells: 3~6S
● Adjustable SBEC Voltage: 5~8.4V (Voltage Step: 0.1V)
● Cont. Current: 40A/60A/80A
● Peak Current: 60A/100A/120A
FEATURES
● Smart Port enabled and telemetry data transmission supported
● Telemetry data for ESC: Voltage, Current, RPM, Power Consumption, Temperature.
● Telemetry data for SBEC: Output Voltage, Current.
● High performance 32-bit micro-processor
● High-precision current sensor ACS781KLRTR-150U-T (Resolution 125mA, Precision 2%) and ACS711KEXLT (Resolution 50mA, Precision 2%)
● Over-temperature and over-current protection
● SBEC supports [email protected]~8.4V (Adjustable through LUA or through FreeLink App with Airlink S)
Neuron 40 MORE DETAILS: https://www.frsky-rc.com/product/neuron-40/
PROMOTIONAL PRICE (TAX EXCLUDED): US$ 49.99
Neuron 60 MORE DETAILS: https://www.frsky-rc.com/product/neuron-60/
PROMOTIONAL PRICE (TAX EXCLUDED): US$ 54.99
Neuron 80 MORE DETAILS: https://www.frsky-rc.com/product/neuron-80/
PROMOTIONAL PRICE (TAX EXCLUDED): US$ 59.99
Estimated Time: February 2019
Jan 16, 2019, 09:45 AM
Sagitta Fanboy
This looks like exactly what people have been asking for in a fully-integrated ESC.
The one thing I see missing is the ability to program it via LUA (beyond just setting SBEC voltage). Being able to fully program the ESC is a great feature that's currently available on Jeti & Graupner ESC's with their transmitters.
That said, if you're heading down that path, F.Port support might be an idea as well. Why have two wires where you can have one.
Also I note the manual says to not turn on the braking function. Braking is a critical feature for any ESC driving a folding prop, as well as regularly used on smaller belly-landing aircraft to avoid prop damage.
Jan 16, 2019, 04:34 PM
pilotpete2's Avatar
As far as using the braking function, I think sumthin got lost in translation
I suspect that warning is not to enable the brake in applications where you're slamming the throttle open and closed frequently. I'm pretty sure it wouldn't apply to a folder on a sailplane.
I have a project that needs a new 40A ESC for the spring. I'll be keeping an eye on these when they are available through the NA FrSky dealers.
Pete
Jan 16, 2019, 07:00 PM
https://hmvc.eu/
Originally Posted by AndreaHuang
FEATURES
Yay..... 10-bit current measurement using hall sensors instead of that being done by BLheli and also Current going to the receiver from the BEC.
You will not hear me anymore about their current ESC. It's now in a funjet. I just don't take the current readings serious.
I think this one will be much better.
Jan 16, 2019, 08:22 PM
Flying in OZ.
iflylilplanes's Avatar
F5J and ALES stop the motor once per flight, can't see that as an issue.
All my aircraft that land on wheels, I've set the motor to idle just like real aircraft, I have found that if the prop is not free wheeling (enough power not to create drag) landings are smoother. Idle is a mix on a switch.
Jan 16, 2019, 08:25 PM
FrSky-MKT
Hello Maws,
The continuous and frequent throttle stick movements (switch between the maximum and minimum values ) under the braking function activated in a very short time (like in 1 minute) would damage the products, it not means you can't turn on this function. This is just a notice to protect the products from the potential damage.
Jan 17, 2019, 03:20 AM
Hello Andrea,
please add the maximum rpm (2-pole motors) in the specs.
It's an important value for users which are using high speed / multi pole brushless motors.
So they could see if the esc would fit for their application.
Udo
Jan 17, 2019, 03:34 AM
FrSky-MKT
Hello everyone,
This short video will tell you where to read the continuous current of BEC and guide you to change the BEC voltage output with 2 ways, one with LUA script, another with AirLink S through FreeLink App. Please check the enclosed connection diagram and you can easily have the function work. ; )
Current Precision
Name: Current Precision.jpg
Description:
Connection Diagram (Part 1 LUA Script)
Name: Connection Diagram (Part 1 LUA Script).jpg
Description:
Connection diagram (Part 2 AirLink S)
Name: Connection diagram (Part 2 AirLink S).jpg
Description:
How to change the voltage output of BEC for Neuron ESC (1 min 41 sec)
Jan 17, 2019, 04:04 AM
https://hmvc.eu/
Hello everyone,
That LUA-script could also give the value of RxBt
In many applications that's the one that is connected to the BEC.
It does need to find out in which telemetry slot it is, but after all it's a programming language....
Jan 17, 2019, 09:50 PM
FrSky-MKT
Originally Posted by strgaltdel
Hello Andrea,
Udo
Hi Udo,
Please check the RPM information, and thanks for your suggestion, we will update the manual as well.
Jan 19, 2019, 04:38 AM
Hi Andrea,
Thanks a lot for the info.
I guess for those of us who intend to use the ESC in planes it would be also interesting to know the erpm value for controlling the device via usual PWM / Servo Output Signals.
Best regards
Udo
Jan 20, 2019, 05:36 AM
The new ESC and the FROS
Dear all,
have some one a information if with the Horus X10 / X12 the ESC via FROS can controll ?
Kind regards
Willi
Jan 22, 2019, 10:26 AM
Sagitta Fanboy
Originally Posted by bruchpilot-64
Dear all,
Kind regards
Willi
Based on the spec sheet the only programming from the transmitter is setting the SBEC output voltage, everything else requires the BLHeli USB programmer.
I would expect the LUA for SBEC voltage will be published for FrOS and OpenTX.
Jan 23, 2019, 10:29 PM
seng30904's Avatar
Are these available for purchase now?
Jan 24, 2019, 04:19 PM
https://hmvc.eu/
No, but HorusRC has them in their "coming soon" section, which often means you can get them next month.
I have the, now obsolete, FrESC32_80A which is however a lot cheaper with its $ 45,-
The Neuron is $ 60,-
New Product FrSky New Arrival - FrESC32_80A Dual SBEC & High Power ESC AndreaHuang FrSky 207 May 15, 2019 08:35 AM
New Product FrSky New Arrival - FrBLS_30A ESC AndreaHuang FrSky 10 Sep 06, 2018 07:34 PM
New Product FrSky New Arrival - FrESC32_35A ESC Release! AndreaHuang FrSky 5 May 06, 2018 05:50 AM
Question Dynamic 40/60/80 acclivity Dynamic Soaring 3 Apr 20, 2016 08:01 PM
News FoxtechFPV New 40/50/60/80 Brushless Gimbal Motors RCGroups Update Multirotor Drone Talk 0 Apr 28, 2014 12:57 PM
