Mar 12, 2019, 04:56 PM
Looks good Jeff. Nice work!
Mar 12, 2019, 05:13 PM
robinson727
T-Bolt
Following along with great interest.. Superior has prop blanks and next time you might consider the ASX "Brick" with on board ESC. It has SAS (stability augmentation system) that works great and isn't "intrusive" and the linear servo's and RX.are bullet proof. The BL -180 brushless motor that is normally used with this system (eFlite GeeBee, Pitts, ect) can be geared and the whole works will fly on 2S 200mah and less. I'm probably going to do a Jimmie Allen enlargement like you have or a Jabberwock (fav.) and while the carbon prop worked great on the scaled up Boston canard, "Valient" a slow turning carved wood prop is a must !! pics: All 3 models used the brick and it's very lightweight and works great..
Sorry for your loss,
Al and the Greyhounds
Mar 12, 2019, 07:20 PM
I'd rather be flying.....
JeffMac's Avatar
Hi Al - - thanks for the condolences and the Tbolt compliments.....
I like your extension shaft set up , and eliminating that gear drive would be a plus....
I have an original Jabberwock plan and need to build that one up someday.....
Thanks again,
jeff
Mar 13, 2019, 07:31 AM
JeffMac's Avatar
Thanks for the kind words, Bob....
Mar 17, 2019, 02:46 PM
JeffMac's Avatar
All -
Tbolt progress has been creeping forward..... Installing pushrods, fitting the nose block to the motor and misc covering has been quietly occuring.....
Good news - weighing all the components : fuselage with all electronics/rods; tail assembly 3/4 covered ; landing gear ; flight battery ; covered wing - came out to 11.1 ounces ( 314.685 grams)..... I'm very pleased....... Adding a wing mount and a few rubber bands + fuselage covering will not add much more .....
More later,
jeff
Mar 17, 2019, 05:11 PM
I like real wooden aeroplanes!
Sundancer's Avatar
Should have excellent performance at that weight Jeff.
Mar 18, 2019, 09:55 PM
JeffMac's Avatar
Yes, George..... Weight goal is being modified to a much lower all up weight ....... 13 ounces or less i think is realistic.....
Tbolt progress -
All the electronics are now installed in the fuselage, including the motor assembly. The fuse bottom and rudder are now covered in litespan red. The Gloss Mod Podge sure works well, I'm very content with the technique.... The covering will continue as the week unfolds....
Then , a wing mount must be fabricated. The basic design on the plan will be used except mounting rails will be added for the wing, and a couple cross braces for mount stability will be added.
The Tbolt will be tested and flown first with a plastic slow flyer prop until i get motivated to carve a balsa prop...... outdoors.....
More later,
jeff
Mar 19, 2019, 09:15 PM
JeffMac's Avatar
Tbolt covering moving along
All -
The Tbolt covering is moving along.... It is amazing how a surplus of covering becomes a scarcity..... The fuse is red, the opposite side needs covered yet..... The wing mount has yet to be figured out and built up....
More later,
jeff
Mar 20, 2019, 06:00 AM
Blueplaidcanard flyer
Looking good!
Mar 20, 2019, 09:32 AM
Originally Posted by rabidrue1
Looking good!
Yes, very nice indeed.
Mar 20, 2019, 11:50 AM
Originally Posted by JeffMac
All -
More later,
jeff
One day I hope to learn to cover like this...
Mar 21, 2019, 08:00 AM
So I'M meant to be in control?
Colonel Blink's Avatar
You and me both - I always start by thinking it's going to go perfectly, but............
Mar 21, 2019, 10:50 PM
JeffMac's Avatar
Tbolt progress
All -
Guys, thanks for the support and encouragement... and undeserved compliments. My photography skills are quite poor which greatly enhances the appearance of my covering efforts. But i am VERY HAPPY with the results so far - the fuselage is completed .... Next, attach the stab and fin. Then, the dreaded wing mount..... Of course, i have not thought much of balance so am hoping for some good luck there.
Anyone using litespan, if you have not tried the Mod Podge process, try it. It made covering a pleasure compared to prior models..... And, it's a really cheap method. Wish everything on this model cost as little as that.....
More later, thanks again,
jeff
Mar 22, 2019, 03:41 AM
Sundancer's Avatar
Looks great Jeff, love the colour contrast.
Mar 22, 2019, 06:05 AM
Nice,ought to be one fine floater when it's done.
Build Log CAP 2019 Dick Korda's World Record Holder 44" electric RC - Flight Video attached JeffMac Vintage & Old-Timer Designs 44 Apr 28, 2019 10:15 AM
Discussion Jimmie Allen Sky Chief by Pat Daily Pat Daily Free Flight 63 May 31, 2016 11:16 PM
Discussion Jimmie Allen Thunderbolt- Not that popular? BMatthews Free Flight 3 May 08, 2016 07:15 AM
Build Log Jimmie Allen BA PARASOL awiatik Free Flight 16 Dec 31, 2015 04:09 PM
