This thread is privately moderated by Ssayer, who may elect to delete unwanted replies.
Jan 15, 2019, 06:48 PM
Oldie, not Moldie
Ssayer's Avatar
Mobula7 Dual Battery Bay (3D Printed)
The M7 is made to work 1S or 2S, but I can't see me running it 1S, since all I have to do on 2S inside is to limit throttle a little in my xmtr and I still get the power of 2S. With that in mind, I drew up a battery bay that would hold both large (450mAh and 550mAh) batteries along with the 260mAh stock batteries, including 300mAh batteries. Here's what I came up with for my 2S setups:
Name: M7 Weight.jpg
Description:
This 3D Printed bay is attached by clipping off the bottom of the current battery bay, leaving 1mm worth of a tab on each of the four arms and simply clipping it in (I use a tiny drop of hot melt glue on each tab just because. Also, it's easy to scrape off the hot melt glue if I want to detach the bay. ). The bay allows easy access to the USB plug.
Name: M7 Large Batteries Bottom.jpg
Description:
Here's what it looks like from the bottom with the large batteries
Name: M7 Large Batteries.jpg
Description:
Right side up (on a green cube spacer so that you can actually see something)
Name: M7 Spacers.jpg
Description:
Spacers so that the stock batteries and 300mAh batteries can be used with this bay and still fit snug
Name: M7 Small Batteries Bottom.jpg
Description:
Here's what it looks like from the bottom with the small batteries
Name: M7 Small Batteries.jpg
Description:
Right side up
Name: M7 All Batteries.jpg
Description:
Finally, a pic with all four different sized batteries in the disconnected bay
Description:
For clarification, the tabs from the old battery bay
Jan 15, 2019, 06:52 PM
Oldie, not Moldie
Ssayer's Avatar
Just a quick note, I found that upping the Throttle MID to 0.70 and adjusting the Throttle EXPO to 0.42 makes this quad sing even with the larger batteries!
Jan 16, 2019, 01:03 AM
3DFun's Avatar
VERY NICE!
Could you design one just to fit 2 x 250mah batteries?
Jan 16, 2019, 08:25 AM
Oldie, not Moldie
Ssayer's Avatar
Originally Posted by 3DFun
VERY NICE!
Yeah, just hollowing out this thing and dropping in some inserts for the 250mah batteries wouldn't be that tough.
Jan 16, 2019, 09:32 AM
Oldie, not Moldie
Ssayer's Avatar
Hah, that was easier than I thought. Ok, it's drawn up. I'll put it on Thingiverse and link to it here.
Jan 16, 2019, 10:19 AM
Oldie, not Moldie
Ssayer's Avatar
Ok, the stl files are on Thingiverse here:
https://www.thingiverse.com/thing:3360080
Discussion 3D Lab Print - 3D Printed Boeing Stearman northernmonkey 3D Printed Planes 858 May 10, 2019 04:58 AM
Build Log 3D Lab Print 3D Printed Spitfire XVI build Fitz Walker 3D Printed Planes 13 Jun 14, 2017 03:44 PM
