Sep 04, 2019, 03:36 PM
Lynxman's Avatar
I tried downloading it. There are three props included.
Sep 04, 2019, 04:25 PM
JustPlaneChris's Avatar
Oh, I see! I didn't download the package from Cults, I selectively got the files from Thingiverse.
Where's that facepalm emoticon when you need it?
Chris
Sep 04, 2019, 10:04 PM
Thanks again! I downloaded the zip file from Cults and yup, there are the prop files.
They look really good in PrusaSlicer. I'm guessing these are printed with 100% infill?
Chris
Sep 05, 2019, 09:51 AM
Lynxman's Avatar
It's best to print them with 0% infill and four to six perimeters and six to eight top and bottom
layers. I print mine like that. 100% would just make the spinner heavier.
Sep 05, 2019, 09:54 AM
Ah, OK. I sliced one at 100% and looked at the layers and it seems like the spinner is still hollow, but the blades are solid. It's easy enough to print a few and experiment. That's why this is so darn much fun. All the "what if" things I get to try.
Chris
Sep 05, 2019, 10:25 AM
Lynxman's Avatar
Yes. It's great to be able to test things so easily. It's why I managed to make a working 120 mm 4 kW EDF for my EL-39 so quickly.
BTW, I hae never broken any of the Nucking Futs props, other than when I crash with power on. Not a single prop has broken on landing even.
Sep 05, 2019, 10:59 AM
That's awesome! I've got most of the airframe printed, and the wings mostly assembled. I'm holding off on gluing the fuselage nose section on until I can do some CG testing and determine which motor I'm going to order.
I'm leaning towards the Great Planes Ammo 24-33-3180, at 67g. Paired with a 3S 850 pack, that should give me a light setup assuming I can get the CG correct.
Chris
Sep 06, 2019, 01:44 PM
Lynxman, I saw a few posts back in the thread where you mentioned you were using a "drone motor" in one of your Nucking Futs versions. Can you share details on what exactly that is? I still haven't decided on a motor for mine.....
Chris
Sep 14, 2019, 12:35 PM
Lynxman's Avatar
Any of the little 2205 motors will fit. Like this: https://www.ebay.com/itm/Dx2205-Mote...QAAOSw3GddbL~6
Sep 17, 2019, 07:10 PM
Lynxman's Avatar
I ordered a 4000kv motor. Speed is addictive.
Sep 18, 2019, 01:43 PM
Haha, sweet! I'm going to repurpose a motor I was running on an old tricopter. It's only 1400kv, so I may go to 4S or just swing a bigger (folding) prop. I'll run tests to see which route makes most sense.
Chris
Sep 18, 2019, 01:53 PM
Lynxman's Avatar
Going for low rpm/high torque might cause difficulties, especially on launch. 4S is a good idea and should provide decent performance with up to 5" props.
Sep 18, 2019, 03:46 PM
Yep, an issue I'm very familiar with on my Wilco hotliner. I've got the ESC programmed for a slow start / ramp up, so I flick the power on and heave it. The power ramps up slowly so it doesn't just torque over on its back. Works great!
Chris
Sep 29, 2019, 06:22 AM
Got all the parts on a scale and the build is almost finished. Specs:
-pla 0.3 width
-full length carbon spar
-modified firewall to even 16mm motor mount spacing and shortened the engine bay to fit the motor
-rc in power gts v2 2207 2750kv
-v good rc airplane 32bit 30a esc
-tattu 4s 650mAh
-aileron d56mg hv, elevator 1109mg
-apc 4,7x4,7
-375g without spinner
Is there .step etc. files available on the front fuselage? Making changes to the stl files on Solidworks is a pain, conversions seem to affect the print quality.
What would be the optimal throws?
Sep 29, 2019, 09:51 AM
Lynxman's Avatar
I use 3DS Max. No step files. If you want a shorter front outrunner "cup just lower the nose into the bed the required amount before slicing.
Beginner Speed 400 Pylon Racer Skullder High Performance 4 Sep 05, 2004 08:26 AM
Speed 400 "Sokol" pylon racer spitfirem9 Electric Plane Talk 6 Jul 27, 2004 08:58 PM
Wing Incidence For a Speed 400 Pylon Racer? W Cole High Performance 6 Dec 02, 2002 12:16 PM
Question for speed 400 Pylon racers Al P High Performance 3 Dec 17, 2001 06:45 PM
Article How To Test Fly a Speed 400 Pylon Racer Bruce Devisser Electric Plane Talk 0 Jul 01, 1996 12:00 AM
