Jan 12, 2019, 04:50 AM
Question
can I paint an foam rc plane?
hello guys,
I am new to rc planes and I was wondering if I could simply paint my foam rc plane instead of covering it with that thin film or tape.
will the ink layer work as a protective tape or film?
by the way, how do you guys call that protective film put all over the fuselage and wings?
thanks.
Jan 12, 2019, 08:30 AM
Build straight - Fly twisty
Whiskers's Avatar
Yes, you can paint a foamy with water based acrylic paint.
Have a look at the thread dedicated to the subject in this very forum:
https://www.rcgroups.com/forums/show...ctional-videos
Jan 12, 2019, 09:43 AM
Build, crash...repeat
AleRRon's Avatar
As Whiskers says, yes you can paint your foamie. I am assuming you are talking about a scratchbuilt plane made with Depron, MPF, Dollar Tree Foamboard, or other foamboard,
I have found that brushing on water based paint on DTFB causes some wrinkling and delamination, but it’s not bad. Spray painting with Krylon or other rattle can paint can work, but I’ve experienced wrinkling. Others have said the trick is to use several very light coats, but I have yet to master the technique. I am now trying a coat of oil based PU that I wipe mostly off before spray painting, I’ll let you know about that. Others have had success with it though.
Depron or MPF(these don’t have a paper skin) can melt with spray paints but maybe others have had luck with light coats. I have used water based craft paints brushed on and that works well. Or airbrushed water based paint also is good if you have the airbrush of course.
You can also precover the foamboard with colored or clear packing tape as described by the guy at Experimental Airlines who is on the scratchbuilt foamie forum.
Jan 12, 2019, 11:31 AM
thanks a lot.
Jan 12, 2019, 07:57 PM
I Look, Listen, and Learn
Timbo383's Avatar
You can use spray cans but you need to hold the can more than a foot away from the foam. It's the propellent in the can that attacks the foam, most of it evaporates at that distance before it hits the foam...of course you use more paint since alot of it is dissipated also.
Jan 13, 2019, 07:18 AM
great info. thanks.
Jan 14, 2019, 11:47 AM
AleRRon's Avatar
Pu
I don’t think I’m the first one to invent this wheel, but I applied brush on oil- based Minwax Polyurethane and wiped most of it off with paper towels and let it dry. Then I sprayed with a can of spray pain. On the model shown here I also masked off some white and then masked the area for the cockpit. I found that if you try to use even blue masking tape on paper covered DTFB, the paper can come off when you peel the tape off. But with the PU on it, the tape comes off easily no problem. And there was no wrinkling or melting of foam using this technique. I think this is a good method.
Jan 14, 2019, 11:52 AM
AleRRon's Avatar
This is my recent model.
Discussion Can i make a plane 100% from the HK foam. Also 3mm or 5mm? Mike Obelengo Foamies (Scratchbuilt) 1 Feb 10, 2016 08:28 AM
Help! I am building an RC plane out of balsa. How do I decide airfoil,wing size , geometry captainteague Scratchbuilt Indoor and Micro Models 6 Dec 23, 2015 03:06 PM
whair can I get free plans to build foam RC plane??? Aksel89 Parkflyers 4 Jul 09, 2004 03:07 AM
Alert Is there an ait plane i can build out of foam that can do 3D without going brushless? lttakas Foamies (Kits) 13 Nov 24, 2003 11:13 PM
How can I learn to fly an RC jet plane zemuron Electric Ducted Fan Jet Talk 12 Dec 20, 2002 11:55 PM
