This thread is privately moderated by parkflyer215, who may elect to delete unwanted replies.
Jan 10, 2019, 11:29 PM
Trader Rating: 86
$23.00 USD
Seller Pays Shipping
Sold
Hitec 75BB retract servo - NIB
NIB. Please PM me for fastest response. Also selling three used servos, can bundle all four for reduced price.
FEATURES
High torque
Travels 180 - full-lock to full-lock - to hold your gear in position
securely. Not proportional. Perfect for mechanical retract
installation.
Water resistant
Ball bearings
INCLUDES
Hitec HS-75BB Servo w/Universal connector, full set of horns,
grommets, bushings and mounting screws
SPECIFICATIONS
Length (Not Including Mounting Tabs): 44mm (1.7")
Width: 23mm (0.9")
Height of Servo Case (Not Including Spline): 25mm (1.0")
Distance/Underside of Mounting Tab to Bottom of Servo: 16.7mm (0.66")
Weight: 35g (1.23 oz.)
Torque: 6.6 kg-cm (92 oz-in)
Speed: 0.5 sec/60
COMMENTS
A retract servo is a very specialized servo. It is non-proportional,
going 180 degrees, "lock to lock". They are specifically made for
mechanical retracts to lock the gear in the up and down positions.
they DO NOT have any means of end point adjustment and can not be
adjusted by ATV on a transmitter. They are only able to go 180
degrees and provide full maximum available torque at the two end
points. This is their whole purpose and intentional design, but if
someone has a unique design situation where they need other than
180 degrees available, then they must use a proportional servo,
not a retract servo. They are specifically designed to withstand
constant holding loads in the up and down positions, unique to the
use of mechanical retracts.
Pneumatic retracts do not need a retract servo. A proportional
standard or mini servo is used to move the air valve back and forth
Jan 11, 2019, 07:59 AM
Trader Rating: 3
I'll take it. Will PM you with my address.
Jan 11, 2019, 08:21 AM
Trader Rating: 86
Thank you! I PM'd you back with my PP
Sold Hitec 75BB Servo NIB bob418 Aircraft - General - Radio Equipment (FS/W) 1 May 21, 2018 11:09 AM
Sold NIB Hitec HS-75bb Retract Servo LaxLife Aircraft - General - Radio Equipment (FS/W) 1 Jun 12, 2017 12:06 PM
For Sale Hitec HB-75BB Low Profile Retract Servo NIB Free Shipping Lancaster RCU Aircraft - General - Radio Equipment (FS/W) 0 Mar 18, 2017 02:08 PM
Sold Hitec HS-75BB Retract Servo NIB planewrecker Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2016 04:57 PM
Sold Retract Servo HItec HS- 75BB Cocg Aircraft - General - Radio Equipment (FS/W) 1 Sep 19, 2015 12:13 PM
