Jan 09, 2019, 10:53 PM
Remove foam from spar
Do any of you have ideas on how to remove the glue residue and foam chunks from this spar so I can reuse it?
I want to avoid sanding, i don't want to create any nasty carbon dust.
Jan 09, 2019, 11:39 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Scrape it off with the blade from a broken propeller .
Jan 11, 2019, 07:02 PM
RJD1234's Avatar
I use a Xacto knife with the blade at 90 degrees to the spar and scape the glue off. Blade doesn't need to be very sharp. Works every time.
Jan 11, 2019, 10:42 PM
I Look, Listen, and Learn
Timbo383's Avatar
A dull blade is best, use a sharp one and you'll find yourself cutting into the spar. Does take time, sit down with a trash can in front of you with a broom and dust pan next to it because only about half will make it into the can while you scrape. Enjoy...
Jan 11, 2019, 11:15 PM
RJD1234's Avatar
Same as what I do. Have reused CF rods many times.
Discussion How to remove decals from foam planes CM_HeliPilot Electric Warbirds 0 Sep 08, 2017 08:01 PM
Discussion How to remove decals from epo foam Wisconsin John Electric Plane Talk 2 Jun 10, 2017 09:42 PM
Question Remove a decal from foam airplane JGallo Painting and Finishing Tips 2 Dec 03, 2016 03:08 PM
Question Is there a better way to remove paint from foam John.G Painting and Finishing Tips 3 May 22, 2016 07:59 PM
Question How to remove hot glue from foam? Soufiani Beginner Training Area (Aircraft-Electric) 10 May 19, 2016 12:28 AM
