This thread is privately moderated by GottaZoom, who may elect to delete unwanted replies.
Jan 09, 2019, 04:32 PM
Up! Up! And Away!
GottaZoom's Avatar
HobbyMate's FrSky protocol RX with SBus, SPort, RSSI outputs
Documenting and testing the Hobbymate FrSky compatible RX.
I've had very good experiences with other Hobbymate products, starting with some 2204 motors that I bought a few years ago and continue to use frequently.
Below is all that came with this RX purchase:
As you can see above, this came with 2 output plugs ... one that can be used for simple SBus output to something like a simple gyro like the A3Super2 I will first use for range testing AND another that will allow me to wire it to a quad's flight controller.
Jan 14, 2019, 04:49 PM
Up! Up! And Away!
GottaZoom's Avatar
Binding was straight-forward for FrSky. Hold the teeny little button when powering up to trigger bind mode.
LEDs
Green with TX connected
Flashing red with TX off
IIRC, there was another LED lit in bind mode (yellow?)
Discovered sensors (nothing connected to RX) are:
1. RSSI working
2. RxBt 0 volts
SBUS output apparently works fine to a connected A3S2 gyro.
Jan 17, 2019, 02:37 PM
Up! Up! And Away!
GottaZoom's Avatar
RSSI appears to be similar to my other FrSky full range receivers.
All of the below using range test mode with RX 18 inches off ground. TX carried down slight hill.
At 30 paces RSSI was about 50 with normal LOS. (Drops to critical if I turned away with body blocking signal.)
At 40 paces RSSI reading was at about 44-46 (varied between under/at low warning)
New Product $10 FrSky XM 1g 16CH SBUS Micro Rx & $16 FrSky XM+ 1.6g Full Range 16CH SBUS Micro Rx lmpuIse Micro Multirotor Drones 118 Jun 19, 2018 03:04 PM
Discussion Problem with Frsky X8R receiver RSSI 0-3.3v output discophil Radios 60 Mar 15, 2017 03:09 AM
New Product FrSky XM 1g 16CH SBUS Micro Rx & FrSky XM+ 1.6g SBUS 16CH Full Range Micro Rx lmpuIse Radios 0 Dec 02, 2016 11:55 AM
Question Is Spektrum's AR7700 Output Comatable With SBUS? gloloph Radios 3 Jul 01, 2016 03:27 AM
Discussion FrSky Rx's with usable RSSI?! JaeMelo Radios 19 Aug 05, 2015 01:11 AM
