Chair-Pak with FPV Pak RCGroups Review
We get our hands on the Chair Pak and FPV Pak combo that turns into the ultimate FPV accessory.
Back when I reviewed the first Chair-Pak in 2016 I thought it was a great idea. It's a backpack for our RC and FPV gear that is also a chair. Most FPV pilot I know prefer to sit down when they fly. Having to carry multiple bags and a chair is a pain so the Chair Pak solves that problem. I've been using it for nearly 3 years now and I love it! I had been waiting for the FPV Pak add-on that was under development at the time, but they ran into some issues that delayed its release. Now it is ready and they sent me a brand new chair along with the FPV Pak to check out.
Video
The Chair Pak
The Chair Pak remains mostly the same as when I reviewed it back in 2016. It has been updated though and the backpack size is a little larger to accommodate the FPV Pak add on. It still has a great quality look and feel to it and is very sturdy. They added a ton of webbing and straps to the outside along with some bungie cords that you can use to attach a couple of drones to the outside. It has more of a tactical look now which is awesome. It comes in 4 colors, Black, Teal, Camo and Blue and sells for $99.99.
The FPV Pak
The FPV Pak is a separate purchase that can be used a stand alone case if you want, but it works best in tandem with the Chair Pak. It's made to fit inside the main backpack compartment and is a perfect fit. It comes with a waterproof cover and has a lot of storage options. I was able to fit in a ton of batteries, my goggles, DX9 radio, extra props and that didn't even begin to utilize all the space available. There is a protective foam wrap for your radio so it won't get damaged and you can fit tools, parts, charging gear and so much more inside. It has a landing pad included that also doubles as a work station and there is a magnetic strip where you can place your loose hardware so they don't get lost. It really feels like they put a lot of thought and effort behind the design to make it incredibly useful. The FPV Pak sells for $79.99.
They hit it out of the park with this combo. I highly suggest you get both the Chair Pak and the FPV Pak insert together. It is the ultimate FPV accessory and you will really appreciate having all your stuff in one place as well as having a chair ready to go whenever and wherever you are.
Check out the Chair Pak and FPV Pak Here
RCGroups.com Review Policies
Our intent is to provide fair and unbiased reviews so that consumers can make informed decisions regarding new products. Some things you should know about our review process:
  • RCGroups.com review items are provided by hobby manufacturers and suppliers, some of whom may be RCGroups advertisers.
  • Review products are sent directly to independent reviewers, chosen by RCGroups.com.
  • RCGroups.com reviewers are not compensated by either RCGroups.com or the reviewed item's supplier. However, they are allowed to keep the review items at no charge.
  • Published reviews reflect the opinion of the author.
  • When a conflict arises between a review sponsor and a reviewer (which is rare), RCGroups attempts to work out a satisfactory solution for all parties. In some cases, this may mean that a finished review will go unpublished, or be subjected to editing for technical accuracy. RCGroups reserves the final say as to whether an article is fit for publication.
It is always our intent to provide a place for honest and open commentary, and to put the needs of our visitors first. If you feel that something we've published is inaccurate, please let us know using the contact form.
Jan 15, 2019, 10:41 PM
FPV REBEL ALLIANCE
Nightstone's Avatar
Now do the review with an average rc flyer. call it an 250-300lb guy. Lets see how it holds up.
NS
Jan 16, 2019, 07:23 AM
RCG Admin
Jason Cole's Avatar
Its rated for 230lbs, but I’ve seen heavier dudes on it.
Jan 18, 2019, 03:40 PM
I'm chiming in to share my thoughts and experiences with this setup. I originally bought the ChairPak in 16 or 17. So, when I ordered the FPV Pak, they shipped out the newer bag free of charge as promised. Replacing the bag was easy conceptually, but took a little effort to get it right, in practice. The instructions were clear, but provided no visuals (none were really needed, it was explained well). Once that was done, the only thing left to do was organize my stuff. I'll just attach a pic to show how I set my FPV Pak up (see below). At first, I wondered if the FPV Pak would be worth the $80...honestly, I pretty much doubted. I am actually very content with the quality of what I received and when you put it all in perspective, I think it was well worth it. The Chair Pak itself had performed well for me, so the addition of the FPV Pak finally completed my setup perfectly! I love all the bungees for securing my quads to the backpack. I love the addition of the launchpad and transmitter gimbal protector (really nice feature). Honestly, it's all the little features that would take too long to detail that eventually won me over!
Left:you can my Spektrum FPV screen, antenna, and DIY google battery
Top: 1s Lipo charger, spare parts, Tx neck strap, etc
Right: Larger black case holds 1s lipos (up to 25), smaller black case holds my Mobula7, and additional DIY goggle Lipo
Bottom: FPV goggles
Much more stuff hidden in other compartments!
Jan 23, 2019, 11:19 AM
TwansFPV
TwansFPV's Avatar
Nightstone:
I can attest that while the legal disclaimer of 230lbs has to be there. It does in fact hold much more. A buddy of mine is about 280lbs and has been using his for 2+ years without incident. The adjustable clasp under the seat is actually rated for 600lbs. And the only part(s) that could ever really wear with sitting use are the two hinge-pins. IF one were to ever somehow snap... it would be a super simple fix (literally like 30 seconds). These pins aren't listed separately on the website for purchase but we'd gladly work out getting some to you.
Brquad:
That's looking great man! I'm happy to hear that you've finally got everything in-hand and all setup the way you like it. I really appreciate you sharing your experiences & impressions with everyone as they are quite helpful to us. I'm a very picky & thrifty shopper myself and totally get why you may have had some initial doubts. In my opinion... it really is (like you said) not so much about any one thing... but more about how everything functions as a whole once it's all setup as a system.
The one thing I might suggest is maybe inverting your radio just to insure there's no pressure on the antenna whatsoever while being carried upright. Totally up to you though.
Thanks again for the feedback guys and happy flying.
Jan 23, 2019, 01:06 PM
Originally Posted by TwansFPV
Nightstone:
Brquad:
Good idea! Think I'll take your advice.
Jan 24, 2019, 11:33 PM
pooljunki's Avatar
i like!!!!!!
Jan 25, 2019, 02:43 PM
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Looks good. I like it!
Dave
Feb 08, 2019, 04:53 PM
So the fpv pack takes the place of the backpack? I’m debating buying one but the price pint is just too high. I either get one used or not at all. This makes my decision easier, if getting one second hand can buy a new fpv pack to replace the bag.
Turns out I’m wrong, it’s totally an insert. Also buying second-hand, no guarantee which pack the original is. I just can’t justify spending $180 on a chair/backpack. No matter how good it is. A good fpv backpack is $100, a good chair is $40. Spending $40 on convenience of not having to make an extra trip to the car or having to carry a bag and a backpack doesn’t make sense to me.
I don't want to sound overly critical, just wanted to state my qualms. I like the idea and I'm sure the product is amazing. I further understand you have to recoup your production, development, and distribution costs. I'm just not ready for that extra $40.
Article Chair-Pak Drone Insert - The Ultimate Accessory Jason Cole FPV Racing 131 Dec 31, 2018 01:06 PM
Review Chair-Pak - FPV Chair and Backpack Review Jason Cole FPV Talk 22 Dec 21, 2018 01:47 PM
News Chair-Pak's FPV Pak Add-On is Here Jason Cole FPV Talk 0 Dec 12, 2018 09:38 AM
Review Eachine VR D2 Diversity FPV Goggles with DVR RCGroups Review Nikolei Zinsli FPV Equipment 4 Jan 24, 2017 01:42 PM
Article Chair-Pak First Look Jason Cole FPV Talk 11 Jun 29, 2016 09:03 AM
