This thread is privately moderated by Keith Kindrick, who may elect to delete unwanted replies.
Jan 07, 2019, 09:48 AM
Messerschmitt Bf-109 G6 flying low and loud
Letís start 2019 with the Messerschmitt Bf-109 G6 flying low and loud in the second half of the video. Stream that section to your AV system and crank the surround sound you wonít be disappointed.
Messerschmitt Bf-109 G6 Low & Loud - DB605 SOUND (12 min 42 sec)
The Bf 109 G-series was developed from the largely identical F-series airframe, although there were detail differences. Modifications included a reinforced wing structure, an internal bullet-proof windscreen, the use of heavier, welded framing for the cockpit transparencies, and additional light-alloy armour for the fuel tank. It was originally intended that the wheel wells would incorporate small doors to cover the outer portion of the wheels when retracted. To incorporate these the outer wheel bays were squared off. Two small inlet scoops for additional cooling of the spark plugs were added on both sides of the forward engine cowlings. A less obvious difference was the omission of the boundary layer bypass outlets, which had been a feature of the F-series, on the upper radiator flaps. Like most German aircraft produced in World War II, the Bf 109 G-series was designed to adapt to different operational tasks with greater versatility; larger modifications to fulfil a specific mission task, such as long-range reconnaissance or long-range fighter-bomber.
To learn more visit:
https://en.wikipedia.org/wiki/Messer...f_109_variants
Jan 08, 2019, 02:54 AM
05RAVEN's Avatar
Thanks for sharing that video! Love the look and sound of that German Warbird! Very cool!
Jan 08, 2019, 10:20 AM
Your very welcome and I'm glad you enjoyed it.
Gallery Guillows Messerschmitt BF-109 16.5 inch jeep1990xj Scale Kit/Scratch Built 8 Oct 21, 2018 09:35 PM
Build Log 24.25" Messerschmitt Bf 109 - Sub 250 grams - Maiden Video up localfiend Foamies (Scratchbuilt) 12 Aug 21, 2016 08:16 AM
Discussion Messerschmitt Bf 109 T, 1:12 stepacz Electric Warbirds 2 May 04, 2016 04:30 PM
Help! Messerschmitt BF-109 F or E (1/5 or 1/4 scale) dstclr Scale Kit/Scratch Built 3 Mar 31, 2016 10:14 AM
