This thread is privately moderated by Gary Chen, who may elect to delete unwanted replies.
Jan 07, 2019, 03:03 AM
Gary Chen's Avatar
Lightweight 30X optical zoom camera for the drone
Lightweight 30X optical zoom camera for drone (7 min 30 sec)
Sky Eye-30XZ is a 3-axis high stabilized gimbal with 1080P 30X zoom camera for drone inspection, surveillance, search and rescue applications.
The 30X optical zoom camera provides 1080P 60FPS full HD video streaming, which will enable you to see every detail you need in the air even you are far away from the object. High-performance 3-axis gimbal is using advanced FOC(field-oriented control) motor control technology which will enable you to get a 0.01 degree incredible precise control, so the gimbal will give you crystal clear and stable video footage.
Compact and lightweight
Sky Eye-30XZ weighs as little as 700 grams to help you meet your payload weight allowance.
Self-adjusting gimbal speed
Sky Eye-30XZ gimbal Yaw/Pitch speed is self-adjusting, which means the gimbal will adjust its speed automatically according to camera zoom value. This is very useful when you try to target the object in large zoom range.
Anti-pull lock mechanism
Sky Eye-30XZ comes with an anti-pull mechanism for power and control signal cable, which will make the wiring very safe in the air, hard to pull out.
Cooling system
There is one little fan on the top of gimbal control unit, will enable the gimbal to work properly in the high-temperature environment.
Features
1) 700grams, lightweight
2) 1/3 inch CMOS SENSOR
3) 30X optical zoom, 1080P/60 HDMI output for video downlink
4) 1080P/30 MP4 video recorded for on-board TF card
5) S.BUS, PWM and serial command control
6) Anti-pull lock mechanism design for power and signal cable
7) 3-axis high stabilized gimbal system
8) Self-adjusting gimbal speed
New Product Sky eye-u30 1080p 30x optical zoom camera with tracking and geotagging charlesfang FPV Equipment 1 Sep 10, 2018 10:09 PM
New Product 1080P 30X Optical Zoom Camera With Auto Object Tracking Module Gary Chen Multirotor Drone Talk 3 Jun 07, 2017 11:10 PM
New Product DJI M100 with 30x optical zoom hdworld Multirotor Drone Talk 6 Mar 15, 2016 02:06 PM
