This thread is privately moderated by bill_delong, who may elect to delete unwanted replies.
Jan 06, 2019, 06:29 PM
Did I make the A Main?
bill_delong's Avatar
Pin Replacement Tools
One of the most important part part of vehicle maintenance (next to cleaning and/or replacing worn bearings) is replacing worn pins on your drive shafts. It's very easy to over look this item and if not addressed (at the first hint of any flat spots forming on the pins) then you risk causing premature wear on the out drives. Once the out drives start to wear, you'll see "cups"form where the flat spots of the pins start to cut into the metal like a knife into warm butter which can cause very inconsistent cornering as the diffs can lock up and you risk snapping a drive shaft. It can be VERY expensive to replace drive shafts and out drives, but it is dirt cheap to replace the pins when you use a pin replacement tool which can pay for itself on the very first use!
Here's an example of worn pins that are so far gone from a very poorly maintained vehicle:
If you only race 1/8 cars which typically use 3mm thick pins, then I would highly recommend the Mugen Pin Replacement Tool because it comes with a ratchet wrench to help keep costs down. High quality "hardened steel" pins are available from Hudy as a great source XRay also sells some pins but they are not listed "hardened" so they may not be as durable. Another option is to buy in bulk off eBay, this has worked for me, but I have noticed they tend to wear a little more frequently.
If you race a 1/10 cars, then chances are you will need to replace 2.5mm pins and RC Renew sells a pin tool with an optional 2.5mm head sold separately. Only problem is that RC Renew doesn't include a wrench and they use a 1/4" square head so you'll need to buy a Yellow Jacket 60616 Ratchet Wrench in order to use their system. ARRMA sells some 2.5mm pins, but really anybody who sells 18-8 or 304 grade pins should work just fine.
Be sure to de-grease your pins and use a micro-torch if necessary to allow the old pins to push out with the replacement tool. Use channel lock pliers to hold the tool and align the shaft flush with the pliers to keep the shaft aligned when driving in the new pin:
Adam Drake from Mugen Seiki Racing shows how to replace driveshaft pins. (3 min 51 sec)
Check out more stuff on My Bookmarks page!
Dec 30, 2019, 09:18 AM
User Registered
RustyUs's Avatar
Are the RcRenew install/pusher screws the same thread pitch as the ones use in the Mugen Seiki Driveshaft Pin Replacement Tool?
Dec 30, 2019, 10:22 AM
Yes, the RcRenew threads are compatible with the Mugen tool
Discussion Wiring connectors, pins and tools, help. Peter Gates Beginner Training Area (Aircraft-Electric) 5 Jan 31, 2018 05:19 PM
Mini-HowTo Finally--> A homemade small pin extract tool for balance taps pins rampman Batteries and Chargers 8 Jun 15, 2012 08:38 AM
Discussion Tamiya pin removal tool? What size pins? zirconx Batteries and Chargers 6 Sep 10, 2008 06:27 PM
Discussion Tool for removing main shaft gear pin oxy Micro Helis 0 Aug 07, 2008 09:26 AM
Question The best way and tool for removing pins Wantafly Electric Heli Talk 1 Dec 29, 2004 07:13 PM
