Jan 06, 2019, 03:17 PM
TommyTomy's Avatar
Fail safe mode for F5J model
dear fliers,
after some unexpeted event realted to lost link between transmiter and receiver, finally ended up hard landing, I have the kind request for simple tips how to fix the fail safe mode for F5J model.
F5J models are quite large and when balasted not fragile as feather, so the way to bring them safely down in emegency condition may sometimes safe property and life. I believe that in all serious competition events fail safe mode should have been checked prior pilots briefing. Nevertheless, one's insurance may not cover the cost of damage.
So, in your opinion, is that better to set the butterly combination (channel position setup)/ other combination or just set up 'hold' for all channels?
Engine stops after max 30 sec. , so channel 1 is not that important, while flying far distances.
What are your regular or atypical settings?
I use Graupner MX20hott
I will appreciate all your support
Jan 06, 2019, 03:50 PM
tkallev's Avatar
My basics:
1. Half flaps with whatever elevator comp comes with it
2. Slight rudder deflection to right or left, pilot's choice
3. Motor off and safety engaged if your programming allows it
Jan 06, 2019, 04:12 PM
Typical? Hold...
Jan 06, 2019, 06:20 PM
I always add flaps and rudder. You want the model to lose altitude and turn. Gives your model the best chance of not being a lawn dart.
Jan 07, 2019, 02:47 AM
When I've bothered to set up a failsafe mode on a big model, I've generally used CROW. I assume that the CROW won't be absolutely symmetrical, so I don't bother with a rudder preset. That was with the old, 72 mHz radios, so I could just get the glider fairly high and turn off the transmitter to see how it flew in failsafe mode. No need to wait for a reboot when I turned the transmitter back on.
Jan 07, 2019, 06:09 AM
In F3J size does matter!
roydor's Avatar
Originally Posted by tkallev
My basics:
In the old days of 72 mhz I once had a model with a similar setup, circle for over a minute overhead while I hunted down the idiot that turned on his transmitter without doing a frequency check.
Jan 08, 2019, 01:34 PM
RV7guy
dnbarrie11's Avatar
Like TK
I use the same basic set up as TK with a couple of minor tweaks. Half flap and elevator comp slightly less than typical landing config. I don't use any rudder.
My main goal if going into Failsafe is to prevent damage/injury to anyone on the ground, not to save the model. Saving the model is great but not the main goal. For that reason, I don't add rudder. I don't want the model to end up in a spin and gain velocity.
Crazy not to set failsafe. In most systems it takes a minute or two.
Darwin N. Barrie
Chandler, AZ
Team Futaba
Jan 09, 2019, 01:33 AM
tkallev's Avatar
I add the slight rudder deflection so that if the cause of the failsafe is related to signal, a slow turn presents all antennae to the transmitter thus increasing the chance to reacquire ...
Discussion DLG Fail Safe Mode(s) BavarianCharles Hand Launch 18 Jul 13, 2016 02:43 AM
Discussion Help please:- Fail safe / RTL mode Jasongib FPV Equipment 2 Dec 15, 2015 02:43 PM
Help! Spektrum AR7600 going into Fail Safe mode wrathofkhan Electric Heli Talk 3 Sep 30, 2010 11:45 AM
Question Fail Safe Mode -You Guys Use It? Murocflyer Electric Plane Talk 33 Jan 11, 2009 11:55 PM
Question Fail Safe Mode -You Guys Use It? Murocflyer Fuel Plane Talk 2 Dec 27, 2008 06:57 PM
