Oct 06, 2019, 05:39 PM
Band1's Avatar
Thanks, still a lot of painting to do before the cold sets in .
Oct 07, 2019, 08:58 PM
needabiggerboat's Avatar
Looks great paul
Oct 11, 2019, 12:07 PM
Band1's Avatar
Ok so this past Monday I gave it two coats of paint and to my surprise there were
still some imperfections that didn't show up with the primer so since I put
quite a bit of work in this truck I wet sanded the entire body .
Tomorrow through Monday it's suppose to be nice so I will give it a
very light coat of primer again to prevent drips and then I will repaint it.
I like this blue color !
Oct 19, 2019, 08:54 PM
Band1's Avatar
Quick update and it's not good.
I painted the body twice and both times there were runs, at 65 -70 D no humidity and I
made sure I was far enough not to get runs or overspray it didn't matter.
I never used Duplicolor paint and I will never buy it again, it was coming out
Of the can like water . I used 2x rusthulium on the smoke stacks and gas tanks and it
came out beautiful. The Duplicolor paint looked like it didn't want to stick on the upright panels
it came out nice everywhere else but not up and down so I reprimed the body and in the spring
I will use the 2x which works great on my other models.
I am now reassembling the chassy and will post pics soon.
Oct 20, 2019, 12:48 AM
Grumpa Tom
Kmot's Avatar
Sometimes rattle can painting can bite you in the butt.
One trick I have used is to place the can in a pot of hot tap water. Let it sit in there for a few minutes. The heat builds up the pressure inside the can and atomizes the paint better.
Oct 20, 2019, 06:25 PM
Band1's Avatar
HI Kmot I have done that in the past , the difference here is that the paint went on
Nice everywhere on the truck but as I mentioned it only ran on the side panels of the
sleeper . I called the company and all they said was it can happen !
This truck because of it's size needs to be painted with an airbrush or a body shop
to get an even color everywhere.
Oct 21, 2019, 08:23 PM
Band1's Avatar
The chassy came out good and with the grey body might not be so bad I
will find out tomorrow .
Oct 22, 2019, 07:43 PM
Grumpa Tom
Kmot's Avatar
lol... the chassis takes up your whole dining table!
How much is that beast going to weigh, all fully built and with batteries?
Oct 23, 2019, 12:11 PM
Band1's Avatar
Enough, that's why I built it in 3 sections.
I put evrything on just to see how it looks
and I think that the grey is nice .
Tomorrow I will cut the shafts, I plan on
going to a company called Stock Drive to
get the gears and to see what they say
about the 12v motor I plan on using
It might not be enough because of the
weight of the truck.
Oct 23, 2019, 04:19 PM
Wow. It's massive hey
Looks bloody good too. Well done mate.
Oct 23, 2019, 04:47 PM
Leftyatm's Avatar
Looks great!
Oct 23, 2019, 05:43 PM
Band1's Avatar
Thanks guys, anybody know where I can get running lights for the roof ?
They have to be at list 1 1/2 " in length .
Oct 25, 2019, 10:23 AM
Band1's Avatar
Sometime this week I will start cutting out all the panels for the interior.
A friend of mine sold me his sound system , it's great for this truck I will
try to post it soon.
Oct 25, 2019, 09:53 PM
Depending on what you're going for exactly, superbrightleds (idk if I can put .com after that) is a good source.
Oct 28, 2019, 11:40 PM
Band1's Avatar
Thanks I will check it out.
I picked up some rubber cushins that will get mounted between the body and the frame
that will serve to prevent the body from shaking and also the body mounts will pass right through.
Once mounted I will post a pic.
Discussion SKYRC SR5 1/4 Scale Super Rider RC Motorcycle GeekBuying Geekbuying.com 1 Jan 05, 2018 11:56 AM
Build Log NSRI Boat with Dual Outboards, 1/10th Semi Scale, Free Build Melbran Scale Boats 43 Feb 08, 2017 08:26 AM
Build Log Aquarius Aquacat Racing Inflatable, 1/6th Semi Scale, Scratch Build Melbran Scale Boats 12 Feb 01, 2017 03:55 AM
Discussion 4-Stroke Saito 50 Powered 1/6 Semi-scale Nitro-Trike Scratch Build Log CONDOR2 RC Paragliders and Kites 0 Jun 11, 2011 11:34 PM
