Jan 05, 2019, 06:29 AM
Help!
My Flysky i6x it's blocked on WARNING screen... please help
i tried:
put all upper sticks to UP position and throttle to down position.
update the firmware witch UPDATER
update the firmware through DFU
the problem when i changed to 10channel and i activated all settings on these screen...
thanks guys
this is the problem...
FLYSKY FS-I6 ESPAÑA Problema con emisora,bajando el throttle se queda (Warning)help me!!!) (0 min 49 sec)
Jan 09, 2019, 01:38 PM
The video is too blurred to really tell what is going on but possibly you have trim set on the throttle channel keeping it from providing the "no throttle" value when the stick is down.
Jan 10, 2019, 04:21 AM
Yes, maybe this is the problem...
How can i fix it?
When i flash the firmware through DFU the controller starts with the same WARNING message...
Jan 10, 2019, 11:58 AM
Jut play with the trims.. the throttle trim in particular. You want them centered. I'm not sure if the screen has a trim position indicator but if so you should be able to see where the model thinks they are set....There might be trim center sound.
Also check the subtrim and limits pages in case you accidentally put something in there to offset the channel
When you create a new model the trims should start centered because they are electronic. The limits and subtrim should all be default to so try that.
Another possible cause is that the sticks need to be calibrated but you should eliminate the above first by trying a new model. I believe the stick calibration is in the "hidden" factory page but it might just be in Setup.
Jan 10, 2019, 03:05 PM
treefinder
springer's Avatar
If you turn the radio on, get the warning, insure all switches are up and throttle down, then press exit button a couple times, or the up or down arrow button , what happens?
I agree with patk that throttle trim might be a cause, but if you can't get off that screen, you can't fix trims.
Jan 10, 2019, 03:58 PM
nothing happens... all switches are up and throttle down
i can't go out of this screen...
Jan 10, 2019, 04:46 PM
possibly the mode setting is switched to mode 2. Try holding the left stick down when you switch the radio on. Once you are in the radio you can set it back to mode 1 if that is what you want.
Help! skyfly fs-i6x locked in warning screen merrob FlySky 1 Jan 04, 2019 06:38 AM
Discussion skyfly fs-i6x locked in warning screen merrob FlySky 3 Oct 18, 2018 10:12 AM
Discussion Flysky FS-i6X problems whit my CC3D ggalex Beginner Multirotor Drones 3 Apr 09, 2017 04:00 AM
Discussion Cleanflight setup screen, my 3D model became an ugly block! blackshark3 Beginner Multirotor Drones 5 Jun 03, 2016 07:41 AM
Help! Help! Burn the Flysky 9x radio, and now shows me 1.1V on the screen Mc.Daniel Radios 13 Mar 30, 2015 11:12 AM
