Jan 04, 2019, 06:59 PM
AMA# SIMAGES
simages's Avatar
Build Log
SA - 1928 AirCamper "100"
Finally, unfinished basement done in new home, we're moved, unpacked and settled......
Good to start building again especially in a 15'x34' hobby shop.
Jan 04, 2019, 07:27 PM
AMA# SIMAGES
simages's Avatar
Specifications
1928 Pietenpol Air Camper (100)
Wing Span | 23.75 in
Overall Length | 15.25 in
Wing Area | 100 in²
Flying Weight | 2.1 oz
Wing Loading | 3.0 oz/ft²
Controls Required | 3 channel, R/E/T
Construction | Balsa / Ply
Category | Micro / Park Flyer
https://www.stevensaero.com/product/...air-camper-100
Jan 06, 2019, 08:08 PM
AMA# SIMAGES
simages's Avatar
Step 34
Like always, nice kit and easy start...
Make sure you follow instructions and you'll be fine. However; up to this point pay close attention to step 29.... square up the parts and don't over sand. Makes a difference with next 2 steps fitting part 28 and 29.
Jan 07, 2019, 03:42 PM
AMA# SIMAGES
simages's Avatar
Fuselage finished and put aside - Step 36
Take care as noted in last step 36 installing ring magnets.
Latest blog entry: SA - 1930 Granger Archaeopteryx
Jan 07, 2019, 04:30 PM
AMA# SIMAGES
simages's Avatar
Tail Group Step 37-42
If you could buy SA kits at HobbyTown, you'd find them in the RC Puzzle section..... Perfect fit.
Note that in step 39, hardwood elevator joiner part E6, is found in the Hardware bag.
Tail feathers set aside...
Last edited by simages; Jan 07, 2019 at 04:35 PM. Reason: Anal Retentive Correction.....
Jan 08, 2019, 06:18 PM
sundtair's Avatar
Thanks, nice workshop :-)
Jan 09, 2019, 03:56 AM
Barnsley Bitter
Mickinsouthyorks's Avatar
Looks a nice build good work
Jan 09, 2019, 09:04 AM
Pappyjkns's Avatar
SIMAGES: Wow! a brand new 15' x 34' workshop?? You lucky duck! Have you checked for horseshoes lately? : )
Cheers!
Lyle
Hamilton, Ontario
Canada
Jan 09, 2019, 10:39 AM
smithdoor's Avatar
Great work shop
Does have AC and heating
Back 1960's most RC work shops where 6'x 10 [1.9 x 2.4 meters] with a window AC Inside the garage
Mind is share with my wife's car and washer and dryer with a sawmp cooler and no heat
It is great work shop AKA [man cave]
Lucky guy
Dave
P.S Great plane too
Jan 09, 2019, 10:59 PM
AMA# SIMAGES
simages's Avatar
Originally Posted by smithdoor
Great work shop
Lucky guy
Dave
P.S Great plane too
My wife and I said that we wouldn't settle for anything less with our last home. So, yes it's really great and yes HVAC installed throughout the 2300 sqft. There are 4 others rooms plus a full bath and one being a she shed..... other 3 are a media/game room, pool room and storage as well as the mechanical room.
So grateful to have such a great space, but a long time coming. Besides, all the aircraft deserve a descent hanger.
Jan 09, 2019, 11:08 PM
smithdoor's Avatar
We down size for retirement the last had 3 car garage I got the third one for metal work
The new place has a 18 x 20 garage so we share
Dave
Jan 10, 2019, 12:35 PM
AMA# SIMAGES
simages's Avatar
Wing Step 43 - 60
Pretty uneventful, but glad to always have CA "un-cure" on the bench. Not always for my fingers......
Pay attention to all Notes, especially to ensure parts are seated flush, oriented and aligned correctly etc......
Jan 10, 2019, 12:39 PM
AMA# SIMAGES
simages's Avatar
Final Assembly
Ready for covering......
Going to use ULTRACOTE Parklite. Cream color because my SkyScout 425 will be covered the same.
Jan 11, 2019, 02:13 PM
AMA# SIMAGES
simages's Avatar
Step 61, Change 1
While doing some Air Camper research I came across AIRPORT-DATA.COM and liked the color scheme of this 1972 PIETENPOL.
So, I'm adding the black to the cream color.
I usually cover the wing bottom first however; because of the dihederal and wing tips. It was easier to reverse stand cover the top first.
Last edited by simages; Jan 13, 2019 at 03:40 PM. Reason: Anal Retentive Correction.....
Jan 13, 2019, 09:54 AM
AMA# SIMAGES
simages's Avatar
Receiver Tray
Step 62 - 65
My Rx/ESC PKZ3351 board was thicker than the slots in the RT nylon clip, but noticed after mounting in the fuselage. Because mine didn't engage to hold in place, I used some 3M Extreme Mounting Tape by filling in the two spaces between the RT bottom skids. I've used this tape in other projects as well as securing gyros, shouldn't add any significant weight either.
Note Step 63
Creating "Pushrod Detail"
All traditional Z-bends lay flat on the bench, but Snake bend tails should be bent so they stand 90 degrees to your bench. The Snake bend is used on the servo endow the pushrod.
Note that you can bend both left and right handed snake bends.
Here’s a link to bending perfect pushrods;
http://www.flyrc.com/bending-perfect-pushrods/
Mini-Review Eachine VTX03S 0/25/50/100/200mw 40CH 5.8G SA with PIT mode - video Frimen FPV Equipment 1 Sep 23, 2018 07:08 PM
Build Log Now a Air Camper (100) from SA NEWBEFLYER Scratchbuilt Indoor and Micro Models 47 Jun 04, 2013 12:36 PM
New Product Stevens Aeromodel 1928 Pietenpol Air Camper 100 FIXED VIDEO Micro Budget Micro Ready-to-Fly 10 Aug 05, 2011 10:08 PM
New Product Stevens Aeromodel 1928 Pietenpol Air Camper 100 Micro Budget Scratchbuilt Indoor and Micro Models 3 Jul 19, 2011 07:18 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
