This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Jan 04, 2019, 09:52 AM
Quad Erat Demonstrandum
scousethief's Avatar
Rave
New Year Promotion-TX805 5.8G 40CH 25/200/600/800mW $8.99 !!!
https://www.banggood.com/New-Year-Pr...tlinkid=109766
These are solid ! i have 4 of these myself and are now my preferred VTX, they are 40ch with selectable mw output including PitMode they have a 5V bec for your DVR/Cam AND have SmartAudio , i cannot fault these at all and i am replacing my Eachine 526 ( which are flawless) with these to make use of the variable output and S.A . Stock up while you can.
Specification:
Brand name: Eachine
Model: TX805
Item name: FPV Transmitter VTX
Frequency: 5.8G
Channels: 40CH
Input voltage: 7V~24V
5V camera supply: 120mA(MAX)[email protected]
5V camera supply: 200mA(MAX)[email protected]
5V camera supply: 300mA(MAX)[email protected]
5V camera supply: 350mA(MAX)[email protected]
Extra features: Smart audio
Power supply: 5V output for Camera
Output power: 25mW/200mW/600mW/800mW switchable
Antenna connector: MMCX
Cable connector: Solder pads
Dimensions: 36mm*22mm*5mm,30.5 stackable hole
Weight: 8g(excluding antenna)
Features:
1. Pitmode
2. Support Smart audio
3. 40 channels with MIC
4. Power failure memory
5. 25/200/600/800mw power switchable
6. Support OSD Configuring via Betaflight FC
7. One button frequency and power setup
8. 7-24V wide input voltage with 5V for camera,12V typical corresponding current value:
25mw-120mA 200mw-200mA 600mw-300mA 800mw-350mA
9. Solid MMCX antenna connection and MMCX brass dipole antenna
Button control Channel select mode
Channel select
Select channels by simple short presses.
Blue LED light on stands for CH1,short presses to change 8 channels sequentially.
For CH2/3/4/5/6/7/8,Blue LED flicker once,it won't light on.
Notice:Blue LED only light on for CH1
Band select
Press button for 2S,Red LED will flash,then short presses to select 5 bands.
Power select
Press button for 4S,Red LED will flash,then select power by simple short presses to select 25mW/200mW/600mW sequentially,For 200mW, Green LED flicker once,it won't light on;For 600mW Blue LED flicker once,it won't light on .Press the button again ,Red LED,Green LED and Blue LED lights together,Represents the highest power 800mW.
Notice:Red LED only light on for 25mW.
Pit Mode(0.01mW)
While in Pit Mode you can change channels and set power levels , but none of these changes will take effect until you quit Pit Mode.By default ,Pit Mode will send a very weak signal.
Two ways to exit pit mode:
Press button 12S until all 16 LED turned off and light on again to exit pit mode,or you can exit pit mode via Betaflight OSD.
Notice:The VTX has memory for settings,To change the settings ,please repeat steps as above.
Package included:
1 x Eachine TX805 5.8G 40CH 25/200/600/800mW FPV Transmitter VTX
1 x Adapter connector cable (SMA Female)
1 x MMCX Pigtail Antenna
1 x Instructions
New Product Eachine TX805 5.8G 40CH 25/200/600/800mW FPV Transmitter -- Free Reviewing BGKevin FPV Equipment 61 Apr 14, 2019 02:22 AM
Mini-Review Eachine TX805 5.8G 40CH 25/200/600/800mW FPV Transmitter TX LED Display Support OSD/P siriusflier FPV Equipment 8 Mar 07, 2019 09:43 AM
Discussion Eachine TX805 5.8G 40CH 25-800mW FPV Transmitter VTX Support OSD/Pitmode/Smartaudio BobFromMars Banggood.com 0 Aug 05, 2018 09:59 PM
