Jan 01, 2019, 11:06 PM
Kimbers Keeper.
BHOFM's Avatar
Pusher VS Slot VS Tractor VS my Wallet!
I am in the process of building two identical planes. one will be a pusher, the other a prop slot. They are Deltas of my
own design. I will ballast for the same weight and both will have the same motor, esc, batteries, prop, servos.
The colors will be different for ID while flying together.
Anyone interested?
Jan 01, 2019, 11:33 PM
Build straight - Fly twisty
Whiskers's Avatar
Of course!
Even though I am ancient I'm always wanting to learn.
It may be a good idea to have the front of the slot and the trailing edge near the pusher prop identical in shape and clearance.
Jan 02, 2019, 01:04 AM
Kimbers Keeper.
BHOFM's Avatar
The trailing edge of the pusher, nearly done does not lend itself to the slot config. I was planning
on making the slot as small as possible for max noise.
This is a similar plane, same wing as the ones I'm working on, you can see at the first of the
video how the trailing edge is done. The planes I'm working on now weigh about half of
what this one does. Same span and length. This is one of my best designs. That's why
I am using the general idea, know good flier.
x1 v2b (4 min 27 sec)
Jan 02, 2019, 01:20 AM
Whiskers's Avatar
Cool!
It does fly nicely.
Jan 02, 2019, 05:40 AM
If it flies - I want one!
Petem's Avatar
Good project! And if you can source a third can of paint, a tractor version with the motor up front would complete the comparison set...
Cheers,
PeteM
Jan 02, 2019, 11:19 AM
Out the Window
High Flyin''s Avatar
Cheers,
PeteM
I second that suggestion. I am thinking of moving the motors to tractor on a couple of my wings.
Jan 02, 2019, 12:32 PM
Kimbers Keeper.
BHOFM's Avatar
You fellows can take a semi simple project and make it a crusade!
I need to assemble a team, buy a building, get a permit, go national
sell stock, build a wall,,,,,
Jan 02, 2019, 02:11 PM
I Look, Listen, and Learn
Timbo383's Avatar
Hmm, I won't mention edf, tri, quad, or two blade prop comparisons also then....
Jan 02, 2019, 02:57 PM
Whiskers's Avatar
... and VTOL
Jan 02, 2019, 03:13 PM
Petem's Avatar
... and of course, a slope soarer version for the purists.
I do love the way that as soon as you have a bright idea, the world is full of advice on how you can do more work to make it better!
Jan 02, 2019, 03:43 PM
flyin' fool
goldguy's Avatar
Yes, you need to add a front wheel drive into the mix.
Jan 02, 2019, 04:07 PM
how tall of a wall?
Jan 02, 2019, 04:11 PM
Kimbers Keeper.
BHOFM's Avatar
Originally Posted by Marty Slater
how tall of a wall?
The FAA says I have to stay under 400'!
Jan 02, 2019, 04:17 PM
Whiskers's Avatar
... so 399.999 feet should do it.
Jan 02, 2019, 05:40 PM
Kimbers Keeper.
BHOFM's Avatar
Add a $ and a couple 00's and you have a starting point!
Discussion TRACTOR Vs PUSHER Excalibre Power Systems 73 Nov 25, 2017 01:30 AM
Question Pusher vs tractor props ChinoDiablo Electric Plane Talk 15 Jan 09, 2017 05:24 PM
Discussion Slot jet pusher, shortening props jim2wright Electric Plane Talk 3 Sep 02, 2012 10:26 PM
Discussion cutting props down for pusher slot jets jim2wright Pusher Prop Jet Models 0 Sep 02, 2012 07:34 PM
Discussion 24 inch and smaller SU-27 slotted pushers Brian Click Foamies (Scratchbuilt) 7 Aug 20, 2008 10:57 AM
