This thread is privately moderated by sir_clive, who may elect to delete unwanted replies.
Dec 30, 2018, 10:57 AM
sir_clive's Avatar
1.5.0 Beta 2 is released!
Description:
We are happy to announce the second public beta version of the upcoming Wing Helper 1.5.0! This version introduces the following new functions and fixes the following issues reported with Beta 1:
  • HOT: Definition of "Shipway" implemented
  • Crash due to invalid position of the rib cutter fixed in DXF and PDF export
  • DXF export: fix for rib comb and aileron DXF export when used together with half-rib cutter
  • NGC export: don't pause when returning from cutting an inner spar
  • NGC export: the panel currently selected in the panel table is now also pre-selected for NGC export
  • NGC export: error handling improved
  • NGC export: two options added for improved compatibility to back-end programs
  • Minor fix in the 2D rib view
  • Helper picture for sheeting: german translation fixed
  • A few typos fixed
  • Minor fix for ICE export
Please make sure to also read the announcement for the Beta 1, especially the warning about the nature and potential shortcomings of beta versions. As always, Beta 2 can be downloaded here.
Many thanks to all of you who participated in the Beta program so far!
By the way, the beauty in the header of this note is designed in Wing Helper by Manni, one of the most active members of the Beta test team, and a Wing Helper wizard. He is much better in using Wing Helper to itsí maximal abilities than I am.
Best regards,
Aleksandar Pozgaj
Wing Helper e.U.
Latest blog entry: 1.5.0 Beta 2 is released!
New Product Kappa 2.0, 2.5, 3.5, 4.0 Bro Electric Competition Soaring-F5J/ALES/e-Soaring 0 Oct 22, 2016 03:35 PM
Question Difference between KK 2.0, KK 2.1.5 & KK 2.1HC boba7523 Multirotor Drone Electronics 3 Feb 19, 2016 08:46 PM
Discussion Kk 2.0 (1.2, 1.5, 1.6); kk2.1; kk2.1.5 griesel Multirotor Drone Talk 1 May 02, 2014 01:38 PM
Question Spider/Speed 1.5/2.0/2.5 Airfoil Toby W Sailplane Talk 4 Nov 22, 2011 06:46 AM
Yippee! thin neo magnet supplier:1.0, 1.2, 1.5, 1.8mm Ron van Sommeren Power Systems 0 Mar 27, 2004 08:38 AM
