Dec 23, 2018, 10:10 PM
BG-Wilson's Avatar
Eachine Tyro79 and Tyro99 Which do you prefer
Eachine Tyro79 140mm 3 Inch DIY Version FPV Racing RC Drone F4 OSD 20A BLHeli_S 40CH 200mW 700TVL
Note:
1. This is the DIY version that comes unassembled.
2. Comes without battery, charger, receiver or remote control.
140mm Racing Frame Kit:
Wheel base: 140mm
Frame arm thickness: 3mm
Upper plate thickness: 1mm
Side plate thickness: 1mm
Frame kit material: 3K carbon fiber & CNC 6065 aluminium
1607 2800KV 2-4S Brushless Motor:
KV: 2800KV
Lipo cell: 2-4S
Weight: 17.8g (includes wires)
Output shaft length: 14mm
Maximum pull: signal 630g (4S 3030 4-blade propeller)
Maximum power: 350W
Configu-ration: 9N/12P
Mounting holes distance: 12*12mm
Mounting holes: φM2
Bearing: NSK
N52 Strong NdFeB Magnet
Recommend propeller: 3 inch
4 IN 1 20A BLHeli_S ESC:
Continuous current: 20A
Peak current: 25A (10S)
BEC output: no
Input voltage: 2-4S
Main control chip: 48mhz EFM8BB2
Firmware upgrade: Supports Dshot600/BLHeli_S/Oneshot125
MOS: 3*3
MOS type: vs3610ae 30v64a
Customized F4 Flight Controller:
Main control chip: STM32F411
Sensor: ICM20602 6-axis
Integrated OSD
PPM/DSM/IBUS/UAR share: UART1-RX
Mounting holes distance: 20*20mm
Weight: 24g
PID circulation rate and refresh rate can up to 32kHz
Supports Betaflight/cleanflight/inav firmware
700TVL CMOS Camera:
Case size: 19mm*19mm
Weight: 9.5g
Total pixels: PAL: 1020H596V (0.61MP); NTSC: 1020H508V (0.52MP)
Effective pixels: PAL: 976H582V (0.57MP); NTSC: 976H494V (0.48MP)
Signal system: PAL/NTSC switchable
Resolution ratio(horizontal center): 700TVL
Video output: 1.0Vp-p/75Ω
Automatic gain control: 0.25/0.50/0.75/1.00, up to 55dB
White balance: off
Exposure mode: electron exposure
Electronic shutter: 1/50(1/60) - 1/100000 S
Gamma correction: 0.45/1.0
Synchronization method: inter-sync
Camera lens: standard 2.1mm
Lens operating voltage: DC 5-12V
Working current: 70mA (low power consumption)
Working temperature: -20℃~-60℃
Humidity: 0%~98%
5.8G 40CH 0mW/25mw/100mw/200mw switchable VTX:
Supports TBS SmartAudio
Transmitting power: 0mW/25mW/100mW/200mW switchable
Channel: 40CH
Full video format: NTSC/PAL
Input voltage: 7V~24V
Power dissipation: +12V/600MW
Weight: ≤3.2g (except antenna)
With copper pipe mini antenna (ipex antenna)
Make sure the antenna is installed at the output end before powering up to avoid damaging internal components.
Material: PC
Mounting hole: 5mm
Center thickness: 6mm
Quantity: 10 pairs
Color: black, red, yellow, green
Weight: 5g a pair
Delivery color randomly (10 pairs of propellers are the same color)
Lipo Battery:
Not included
Recommend 2-3S 450-650mah
Latest blog entry: Ways to contact me
Dec 24, 2018, 01:59 AM
The new low has been set! I bet the price will be $79 .
Interesting to see if this CMOS camera is good or bad. Props definitely needs to be changed. Motors are big, but the KV is moderate.
The bottomline is the price. Everybody, who is looking for the cheap should be satisfied
Dec 24, 2018, 02:02 AM
Sumfear's Avatar
Both of them are good starter multis, but I prefer smaller ones as the Tyro79 to start with. Damages are less when u crash...
Dec 24, 2018, 03:17 AM
FPV addict
mlilasic's Avatar
For starter pilots smaller, both in price and size, is better.
Dec 24, 2018, 07:54 AM
Kratos89's Avatar
This is exactly what I am looking, low budget FPV drone, I have experience with big bird tarot 810 for aerial view, but no with racing drone, and I want to buy one for hobby and race, is this any good, what would you recommend, I want quality, with not too much price. Also somebody recommend good simulation for racing drone free and buy option?
Dec 24, 2018, 11:06 AM
(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)
JohnCC's Avatar
Tyro79 looks really good on paper. Miniquad world has been popular, so this will be a nice option for people.
Dec 24, 2018, 11:48 AM
Fan of just about anything RC
SoloProFan's Avatar
I built the Tyro99, so if I get the chance to test a Tyro79 kit, I can tell you which one I'd prefer.
Latest blog entry: For the love of the hobby!
Dec 24, 2018, 09:33 PM
BG-Wilson's Avatar
haha That makes sense
Dec 24, 2018, 09:35 PM
BG-Wilson's Avatar
This one is a good choice
Dec 24, 2018, 09:36 PM
BG-Wilson's Avatar
sounds cool!Where is your review thread?
Dec 24, 2018, 09:38 PM
BG-Wilson's Avatar
Merry Christmas, everyone!
What do you think of this Frame Kit?
We want found someone to review it
https://bit.ly/2Q2NXQq
Dec 24, 2018, 09:40 PM
BG-Wilson's Avatar
I think so too
Dec 24, 2018, 10:02 PM
Beginners should be aware , the 99 motors have enamelled wire with tinned ends . If you shorten the motor wires you will have problems soldering them .
Dec 24, 2018, 10:51 PM
alex_nikiforov's Avatar
Eachine offers its products in various segments, now in 140mm size. I like quadcopters in this size, last summer I fly Kingkong FPV Egg 136 . Compared to the larger models, he gave me more emotions. This model is more accessible, resistant to damage and suitable for beginners on 2s battery. Who needs more power then 3s batteries.
Dec 25, 2018, 01:49 AM
SoloProFan's Avatar
By the time I got it, there was already a large thread running, created by Scousethief. https://www.rcgroups.com/forums/show...-Owners-Thread
Since Scousethief did a really good job on this, and added info, and many pictures after he received the quad, I didn't see any purpose in making a second review thread, I added my remarks and flight video to that thread instead.
Had there been a review thread with just a single video, and no other info, I would have started a new thread, and try provide as many info as possible, but in this case, I would just be repeated what someone else already posted.
Discussion Which Action Cam do you prefer? RunCam2 or FoxeerLEGEND? rclab1 FPV Equipment 4 May 27, 2016 11:54 AM
Poll Which do you prefer? ESC on the Arm or Inboard? TheDuke99 FPV Racing 3 Apr 24, 2016 05:13 PM
Discussion Which props do you prefer? ABS, Nylon composite, CF? quad_squad Multirotor Drone Talk 1 Jan 09, 2016 03:02 AM
Discussion Which Flight Controller do you prefer? Naza V2 or Pixhawk? myrcmodel Multirotor Drone Talk 5 Nov 06, 2015 02:48 PM
