Dec 21, 2018, 01:42 AM
Emax TinyHawk w/Spektrum DSMX RX
For those of you wanting to fly the TinyHawk on Spektrum, get you one of these tiny DSMX RX SATs on Amazon for $16 and solder it in yourself: https://tinyurl.com/yakn6gg6
It needs to be soldered to 5V, GND, and RX2. I used the same ground the camera is on, & there is also 5V on the same side of the board. The RX2 pad is on the opposite side of the board (battery side)...
In BetaFlight, disable serial port (UART) 1 and enable port 2. Set port 2 to serial, Spektrum 2048.
The RX fits inside, but just BARELY, and only in a specific spot. In the last photo you can can see the extra wiring, antenna sticking out, and a tiny corner of the RX under the main board in there.
I don't know if it flies any different with that tiny bit of weight added, but I wouldn't know the difference because I didn't fly it until I got the DSMX RX in it. (TinyHawk was gifted to me)
Props to MadMax for giving me this quad & the heads up on that little DSMX RX!
Dec 23, 2018, 07:16 AM
Fan of just about anything RC
SoloProFan's Avatar
Thanks for the excellent write up and permission to add this info to my review thread.
Latest blog entry: For the love of the hobby!
Dec 23, 2018, 04:13 PM
No worries!
Mine flies pretty good with the little RX in there!
Someone else found this tiny RX @ Newbee: I'm sure it would work the same, but should save some weight not having the connector, and it might be even smaller overall.
https://newbeedrone.com/collections/...tible-receiver
Feb 04, 2019, 09:30 AM
U lookin at me?
Baddmove's Avatar
Thanks for this, I have been looking for a good micro receiver for such a conversion. I just picked up the one in the last post so we'll see.
Feb 25, 2019, 04:22 PM
that's gonna leave a scar
KCinNC's Avatar
I've tried to solder on a fullspeed dsmx. I don't seem to be getting any power to the rx ? I soldered the +/- to the sbus pads. I am assuming this is 5v +/-. then the yellow to the RX2 pad..
I also changed the uart port to 2, disabled 1 . but it will not stay ?
on top of that, to bind. I have to go to the CLI. type in "spektrum_sat_bind=9" it says unknown command
sure I have something wrong...crazy: rolleyes:
Feb 25, 2019, 04:32 PM
+/- go to power and ground, not sbus pads. Not sure what your RX needs as most DSMX RX's are 3.3v, but the one I used was 5v.
The command is "set spektrum_sat_bind=9"
Then "save"
Feb 25, 2019, 04:49 PM
KCinNC's Avatar
Originally Posted by DesertClimber
+/- go to power and ground, not sbus pads. Not sure what your RX needs as most are 3.3v, but the one I used was 5v.
Then "save"
man, thanks for the quick reply. I'll search for the other +/- pads.
the instructions to bind did Not read "set spektrum" that probably is where the bind process is wonky
and yeah 5v required
again thanks DesertClimber
Feb 25, 2019, 04:52 PM
I don't have mine handy or I would look, but the 5v, ground, and RX2 pads I used weren't anywhere close to each other or even on the same side of the board! LOL
Good luck and post up when you get it flying!
Feb 27, 2019, 08:27 AM
I'll be doing this very soon with this RX. Thanks for this post. Just eagerly awaiting my TinyHawk to arrive.
Feb 27, 2019, 04:45 PM
I also bought the newbeedrone beeceiver and it's even smaller! No connector, etc, so it also shaves some weight.
Feb 27, 2019, 06:08 PM
KCinNC's Avatar
I got mine powered up and flying. Binding was no problem . Thanks for the help DesertClimber
Feb 27, 2019, 06:12 PM
Awesome!
I'm looking into the "project mockingbird" setup, so we'll see if it flies even better!
Mar 01, 2019, 12:21 PM
I ended up installing one of the BetaFPV DMSX receivers in mine yesterday and it's working great. So far it's the smallest/lightest DSMX Rx that I've found.
Mar 01, 2019, 01:03 PM
My Longbow arrived last night and my TinyHawk should be waiting for me when I get home tonight. Time to take it apart and solder it back up. Hope it's not a hard process. Soldering is not my best skill.
Mar 01, 2019, 09:30 PM
So it seems I did the same as you - SBUS 5v and -. So when you got yours working - what did you move it to?
Discussion Emax TinyHawk - Family- Racing Whoop? (1-2s) v2 & FreeStyle (II) TinyHawk II & Race Frimen Micro Multirotor Drones 3151 Jul 15, 2021 09:03 PM
New Product EMAX Official - Tinyhawk - Micro Indoor Racing Drone EMAX Yin Yan Micro Multirotor Drones 38 Oct 01, 2019 10:47 PM
News EMAX TinyHawk Brushless Micro Drone Jason Cole Micro Multirotor Drones 19 Dec 21, 2018 03:45 AM
New Product Emax Tinyhawk Indoor FPV Racing Drone BNF F4 4in1 3A 15000KV 37CH 25mW 600TVL VTX 1S smg24 Banggood.com 1 Nov 03, 2018 07:26 AM
