Dec 18, 2018, 04:04 PM
Exceed RC 1/8Th Green Mad Torque Rock Crawler Ready to Run RC Remote Control Radio Tr
Exceed Mad Torque Rock Crawler Review (3 min 37 sec)
https://www.nitrorcx.com/03c09-madtorque-green.html
The Rock Crawler embodies good features from real rock crawlers. Multi-link suspension and axles provides all 4 wheels through A center-mounted 3-gear transmission, providing tremendous grip and torque at all times and overcome any obstacle that it may meet with.
Features:
Full ball bearing throughout whole vehicle
Multi-link suspension allows for smooth crawling
Four wheel driving provides tremendous grip for wheels
"Truck/Hammer/Wecker" style body
Alloy lower suspension link bars with captured ends
Solid axle mount provides protection for front/rear shaft
High precision ESC w/ reverse function
High precision 2 channel receiver
Designed from the get-go as a rock crawling machine that goes anywhere.
Super long nitride coated shocks offer a wider range of articulation.
The 2.4Ghz RTR Exceed RC Mad Torque transmission was designed to place the weight of the motor as low as possible to maintain a low CG (Center of Gravity).
The 2.4Ghz RTR Exceed RC Mad Torque chassis is lightweight and stiff.
Advanced battery mounting design.
Axle -Mounted steering servo.
Dual High-torque 540 motors.
Advanced tire pattern provides best grip and balance.
High performance electronic speed controller.
Advanced monster stocks design provides the best support.
Unique Aluminum Alloy twin vertical plate chassis design
Revolutionary multi-link crawler suspension design
Heavy duty special harden metal ring and pinion gears, axles and axle shafts
Advanced aluminum alloy suspension links
Advanced locked differentials four wheel drive design
High performance motor design
High performance heavy duty rock crawling servo
High performance racing level 7.2v 3300mah ni-mh battery.
Motor: 540 Motor
Bearing: Ball Bearing
Length : 22.83 inches (580mm)
Width: 13.94 inches (354mm)
Height : 9.25 inches (235mm)
Wheelbase: 16.54 inches (420mm)
Weight: 2970g
Batteries: Ni-MH 7.2V 3300mAh
ESC: Electric Speed Control
Radio: 2.4Ghz Pistol Remote Control
Receiver: 2.4Ghz 4CH FHSS Receiver
Jun 04, 2019, 10:47 PM
Windy Heap's Avatar
sweet rig.
just bought one.
need some aftermarket shock help, and want to go for 4WS.
radio of choice for the extra channels?
Discussion Exceed RC 1:5 Scale Maxstone Rock Crawler 2.4GHz Ready to Run RC Remote Control Radio Nitro_Nancy NitroRCX 0 Sep 17, 2018 04:04 PM
Discussion Exceed RC 1/8Th Green Mad Torque Rock Crawler Ready to Run RC Remote Control Radio Tr Nitro_Nancy NitroRCX 0 Sep 17, 2018 03:58 PM
Discussion Exceed RC 1/8Th Orange Mad Torque Rock Crawler Ready to Run RC Remote Control Radio T Nitro_Nancy NitroRCX 0 Sep 17, 2018 03:51 PM
Discussion Exceed RC 1/8Th Mad Torque Rock Crawler Ready to Run (Blue) RC Remote Control Radio T Nitro_Nancy NitroRCX 0 Sep 14, 2018 04:53 PM
Discussion Exceed RC 1/8 Scale Mad Torque 8x8 Crawler 2.4ghz Ready to Run RC Crawler RaidenCharlie NitroRCX 0 Apr 08, 2016 04:57 PM
