FMS 1700mm (67") Piper PA-18 Super Cub
As a relative of the popular 1400mm J-3 Cub, the 1700mm PA-18 Super Cub retains great flight characteristics while offering increased power and wingspan.
From FMS
The Piper PA-18 Super Cub is a two-seat, single-engine monoplane. It was developed from the Piper PA-11. In close to 40 years of production, over 9,000 were built. Super Cubs are commonly found in roles such as bush flying, banner towing and glider towing.
Thanks to its functional flaps, high-lift airfoil, rugged landing gear and oversized balloon tires- the 1700mm PA-18 Super Cub has impressive short take-off and landing (STOL) performance, allowing it to operate from just about any terrain.
Utilizing the latest FMS hardware and design, the 1700mm PA-18 Super Cub has pre-installed ball-link type pushrods, integrated servo connectors in the wing structure and can be assembled very easily using no glue at all.
For pilots wanting to get the genuine bush-plane experience, the PA-18 Super Cub can be equipped with floats.
Versatile, fun and exceptionally relaxing to fly- the 1700mm PA-18 Super Cub is a great addition to any fleet!
Features:
  • 1. Powerful 3541- 750KV Outrunner motor with Predator 45A ESC provides adequate thrust for any situation.
  • 2. CNC metal landing gear structure for less-than-perfect landings.
  • 3. 6.25-inch oversized balloon tires for all-terrain operations.
  • 4. STOL capable (Takes off in less than 3m/10ft)
  • 5. Pre-installed navigation and landing lights
  • 6.Two-piece wing and horizontal stabilizer for easy transportation
  • 7. High-strength carbon fiber wing spars
  • 8.Integrated servo connectors
  • 9. Screw-together assembly
  • 10.Large battery bay
  • 11.Ball-linked pushrods for increased precision
  • 12.Tough two bladed Nylon propellers
  • 13. Functional flaps
  • 14. Optional floats and stainless-steel wing struts
FMS 1700mm(67") Piper PA-18 Super Cub-Features (1 min 21 sec)
Specs
  • Wingspan 1700MM/66.9in
  • Overall Length 1136MM/44.7in
  • Flying Weight 2100g
  • Motor Size 3541-KV750
  • ESC 45A
  • Servo 17g*6
  • Radio 6 Channel
  • CG (center of gravity) 80-85mm(From leading edge)
  • Prop Size 12*7.5, 2-blade
  • Recommended Battery 14.8V 2200-2600mAh 4s 35C
  • Aileron Yes
  • Elevator Yes
  • Rudder Yes
  • Flaps Yes
  • Retracts No
  • Approx. Flying Duration 10-15 minutes
  • Minimum Age Recommendation 14+
  • Experience Level Intermediate
  • Recommended Environment Outdoor
  • Assembly Time 15 minutes
  • Is Assembly Required Yes
  • Material Durable EPO
  • Package Options PNP
  • Requires PNP Requires Radio System, Battery and Charger
FMS 1700mm(67") Piper PA-18 Super Cub-Build video (4 min 56 sec)
Photos
Learn More
Go to the FMS page for more info!
Visit the RCG thread about this bird already in progress!
Dec 17, 2018, 10:38 AM
ɹǝʎןℲ ǝıssn∀
taz101's Avatar
Here's an idea Jim.....
How about when you start a new "News" thread, about a plane that's actually been out for 3 months, you put a link in the story to the original thread that has been going for the 3 months.
It would help people to find out more about the plane, instead of having them ask questions here!!
Here is the thread.....
https://www.rcgroups.com/forums/show...A-18-Super-Cub
LURCH
Dec 17, 2018, 10:40 AM
Admin Deluxe
Jim T. Graham's Avatar
Done and done!!!
New Product FMS 1700mm(67") Piper PA-18 Super Cub taz101 Electric Plane Talk 456 Feb 06, 2019 08:10 PM
Discussion Piper Pa-18 Super Cub packardpursuit Scale Drawings and Three Views 20 Jan 10, 2016 04:29 AM
