Dec 16, 2018, 11:57 AM
Foam is my friend!!!
NewZee's Avatar
Question
Wire Landing Gear for Foam "Profile" Airplanes??
Hi All,
I'm completing a profile 3D flyer , made from "Lowes" 1/2" thick Blue Foam. I'll use a light "Spring Steel" wire landing gear with some lightweight wheels, and I'm looking for good ways to secure the wire landing gear to the foam fuselage?? I've got some ideas, but thought I'd reach out to the community for good ideas, suggestions! here is a pic of what the plane will look like (This one is not mine)!
Dec 16, 2018, 12:38 PM
flyin' fool
goldguy's Avatar
I've used this method on profile designs of all sizes with good success .......................................… https://www.rcgroups.com/forums/show...&postcount=215
Dec 17, 2018, 06:47 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
We mount the gear to the motor stick where it’s solid with the fuselage and less likely to tear out …
Latest blog entry: Lost plans
Dec 17, 2018, 07:08 AM
Kimbers Keeper.
BHOFM's Avatar
I just wasted half an hour looking for a picture, that is how I do mine, when there is a lower fuselage, I notch out
for the stick, I just use three or four inch long piece and epoxy it in. Never had a problem with this design.
Dec 17, 2018, 08:19 AM
gpw
gpw
gpw's Avatar
The stick ( Bamboo chopstick) alone adds tremendous strength and stiffness to the whole front end of a Profile fuselage … Like BH said … it works …
And in reality , for LAR planes we really like the Monowheel , easy , half the parasitic drag ..
Dec 19, 2018, 09:47 AM
r/cdawg's Avatar
Yup, I do mine the same way. I mostly use carbon fiber for the struts but then again I fly off reasonably smooth pavement most of the time.
Dec 20, 2018, 09:46 AM
Scratch builder
I like what you already have, but would drill SMALL holes so I could run tie wraps through
the wood. Two locations would be good.
Dec 20, 2018, 12:03 PM
flyin' fool
goldguy's Avatar
As pictured in post #1, it's a torsion bar type gear and prone to spread too much.
Discussion Who was looking for wire landing gear? David2011 Fuel Plane Talk 4 May 15, 2018 09:05 PM
Discussion Large Slow foam plane with Landing gear Kooshball Electric Plane Talk 11 May 12, 2016 11:42 PM
Discussion Best cheap wire (or other material) for landing gear for 1m wingspan foam planes RC Aerobat Electric Plane Talk 19 Oct 30, 2013 03:47 AM
piano wire for landing gear for 2lb edf Fiasco Electric Ducted Fan Jet Talk 11 May 24, 2005 07:02 PM
