Dec 16, 2018, 09:34 PM
treefinder
springer's Avatar
original manta
here's the main wing template for the original Manta. It is made from Readiboard, and I made a triangular section fuse to save weight. It wasn't exactly successful. I like to keep all the gear "inside", and the triangular section made it difficult. Aft of the wing was a single vertical sheet to hold the dihedral. The whole thing is pretty fragile. I think if I did it over, I would make a box section fuse with tapered plan view like the BW32 - more room inside, and stronger.
Dec 16, 2018, 09:40 PM
treefinder
springer's Avatar
Here's a picture showing the progression from original manta through a larger MPF manta to the BW32. My fave is the BW32, most versatile flyer, and as slow as the original manta.
Dec 16, 2018, 10:28 PM
skumgummi dave
Thank you for the plans Mike. I appreciate them.
Dave-
Dec 17, 2018, 01:15 AM
Mike, thanks for beautiful plans .
I prefer BW32,maybe build one someday.
Where is the C.G of BW32 ?
Dec 17, 2018, 03:08 PM
skumgummi dave
I sent you a pm Mike.
Dave-
Jan 27, 2019, 09:49 AM
Bow and arrow
My specs:
Wingspan:43.3" (110cm)
Length: 22.8Ē (58cm)
Motor:2208 1100KV
Battery: 2S 7.4V 860mah
Servos: 2x 9 gram
Props: 9x5
Auw: 310g
Jan 27, 2019, 12:24 PM
treefinder
springer's Avatar
Very cool! Like the landing gear, I'll have to try that on mine! How does she ROG?
Jan 27, 2019, 09:54 PM
Hi ,Mike:
I really like your design and build one with landing gear but have no rear wheel steering.
I am puzzled where is the C.G of BW32 ? Thanks!
"How does she ROG? " -->It's still not yet first flight,maybe by hand launching
Jan 28, 2019, 10:04 AM
treefinder
springer's Avatar
My CG came at 4" aft of motor mount. With the additional drag of gear pitching nose down, a bit farther aft might be better, though. Post Video if you can get some!
Jan 28, 2019, 11:14 AM
Thanks,Mike!
I will post video if she has its first flight!
Jan 29, 2019, 08:50 PM
agfrag's Avatar
BW30 Maiden Flight
Got in a wonderful maiden flight this morning with my BW30 (roughly 30 inch wingspan due to size of foam sheet I used). Got 18 minute flight with a 450mah 2S battery.
Pics are right after completing the build, and post maiden at the Skymaster's indoor fly at the Ultimate Sports Arena in Pontiac Michigan.
From the hand toss launch to landing, the BW flew like it was on rails. Seriously, it was the best maiden I've ever had.
I landed once after about 3 minutes to adjust the battery location forward to change the CG, and add some expo to the rudder and elevator, but the rest of the flight was non-stop, at a steady even cruise rate. My thumbs started to get tired!
I had initially calculated a CG of 3.75 inches (~95mm) but I adjusted it to 3.25 inches (~83mm) behind the motor mount.
I'm thinking of attaching front wheel struts to the motor mount, and a rear wheel to the under slung rudder, simple! But then again, it looks so sleek without wheels, hmmm...
What a great design Mike! Let the variants begin!
Jan 29, 2019, 10:55 PM
Wow! Agfrag,beautiful BW30!
Jan 29, 2019, 11:09 PM
It's possible to Rise Off Ground,but fail first time because less power!
As always then throw it by hand.
flight video:
Bow & Arrow (2 min 16 sec)
Jan 30, 2019, 01:59 AM
Mike's original wing span is 32",I enlarge to 43.3" and made a small change to join the fuselage.
It's really a good design and easy to diy and fly.
Mike, if you don't mind, I put it on to share it.
Jan 30, 2019, 09:46 AM
I Look, Listen, and Learn
Timbo383's Avatar
Looks like we have a winner here Mike. I'm already thinking about ailerons....I know, doesn't need them, but hey, why not.
Discussion need help for a 4000mm wing span giant Scale EDF blended wing body desing mohsenfjs RC Airliners (Commercial, Cargo, Troop Carrier) 5 Apr 23, 2018 09:45 PM
Help! Wing fillets/ blending in SolidWorks Altocirrus CAD/CAM 15 Nov 11, 2011 11:11 AM
Discussion Continuing adventures of Patrick Kennedy aerogel Life, The Universe, and Politics 45 May 10, 2006 01:57 PM
The continuing adventures of the Mini Max Vonbaron Parkflyers 7 Dec 22, 2001 07:24 AM
