Dec 14, 2018, 09:55 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Long EZ
As I have been playing with canards (sort of) I got to thinking maybe I would build a canard .. so had a look and can only find one scratch build of the "Long EZ" and thats form FT
So here goes with my version of the Long EZ .. I will be using HK foam for most of the build .. I will use 6mm Depron (real Depron) for the formers, ribs, ailerons, canards and wing tips
As most of you know if you have used HK foam, its 5mm thick and a little on the soft side .. but fine for wrap over wings and fuselage covering .. I prefer to do the other parts with 6mm Depron
Should be a fairly quick and easy build .. all slots are made for 5mm, so it would be OK to use MPF as I believe its a tad over 5mm thick.
Lockey
Dec 14, 2018, 11:54 AM
When cows fly!
Can't wait to see this one fly!
Dec 14, 2018, 02:53 PM
Nice! I didn’t like the FT version so did my own as well.
Dec 14, 2018, 04:33 PM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Love the LE
Dec 14, 2018, 07:59 PM
Lockey's Avatar
Hey Duke, have you had chance to make a start in the Firefox?
jpot1, did you fly her ? any Video ?
David, when are you going to start some building and flying mate ?
Lockey
Dec 14, 2018, 10:22 PM
Lockey
Great flyer. Plans are posted on the FT forums.
FT style Long EZ (2 min 1 sec)
Dec 14, 2018, 10:36 PM
Dukejet's Avatar
Hey Lockey! I have the plans on my memory stick ready for printing. Will have plans printed out this week coming ...one way or another.
Dec 15, 2018, 07:02 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Lockey , from much canard experience , I’d suggest for your model , enlarging the Canard a bit to work better in our “scale air” … The canard is the thing that makes the flying qualities unique , and the bigger surface only helps make it better … and more stable . Just a suggestion …
Latest blog entry: Lost plans
Dec 15, 2018, 07:10 AM
gpw
gpw
gpw's Avatar
Scale canards that “look right” usually are pretty innefective on our models … Just saying ...
Dec 15, 2018, 08:26 AM
Lockey's Avatar
Thanks for your input gpw, always welcome ..
Do you think I have added enough ? I added about 6 mm to the canard chord and about 10mm to the wing chord
I am showing the plan view, does it look about right ?
Lockey
Dec 15, 2018, 02:03 PM
gpw
gpw
gpw's Avatar
The flying will be the proof … Technically the canard will stall before the main wing , dropping the nose and gaining airspeed , preventing the main wing from ever stalling , which means it will do a nose bobble type of stall and you can do crazy things like drop the plane almost straight down in a stall … or do some incredibly flat spins … with no rudder … The smaller the canard the less effective this becomes as you have to compensate by moving the CG rearward for the smaller canard … It’s a matter of experimentation … and did I mention the canard likes 3-5 degrees of positive incidence … that’s important …
GPW's Foam-EZ Canard (0 min 22 sec)
Dec 15, 2018, 06:38 PM
Dukejet's Avatar
Looking great Lockey. Bit of extra cord never did any harm
What sort of wing span you thinking?
Is there any chance the fuse could have a rolled top and a flat bottom?
I don't think I have see a Long easy with an edf on the back...... hehe
Dec 15, 2018, 08:43 PM
Lockey's Avatar
I guess I could do a rolled BACK at the top Duke, ther real one was quite square at the front (sanded round edges) .. EDF Long EZ .. now that sounds like fun
Thanks for the video gpw, how do you get her into a flat spin ? Yes mate already put 3° on the canard.. thanks .. how about an estimate for the CG
Lockey
Dec 15, 2018, 09:17 PM
Sokol
JureZ's Avatar
Lockey
as I don't know your plane's dimensions, suggest using this link:
https://rcplanes.online/cg_canard.htm
Dec 15, 2018, 10:21 PM
Lockey's Avatar
Thanks JureZ .. ( see pic ... does this look about right ?
Hows this Duke ? (see pic)
Lockey
Mini-Review General Hobby .46 size Long EZ ARF rutanman Scale ARF/RTF 9 Oct 18, 2018 05:43 PM
Help! ST. Croix Models Long - EZ ..(Need MANUAL) luis94 The Builders Workshop 2 Feb 24, 2017 08:12 PM
Help! ST. Croix Models Long - EZ ..(Need MANUAL).. luis94 Balsa Builders 0 Feb 14, 2017 07:25 PM
Build Log Rutan Long-EZ Scrathbuild esc.:1:8 Scratch Built DonAutogiro Scale Kit/Scratch Built 4 Nov 22, 2016 03:44 PM
Build Log "Hyper EZ" a Long EZ varient... mudman1959 Foamies (Scratchbuilt) 11 Apr 25, 2009 05:03 AM
