GliderThrow - Measure Control Throws
Now this is pretty neat and something fun and useful for us tech nerds out there. GliderThrow is a small electronic device that you attach to your control surfaces to measure and set the surface deflections.
Measure Control Deflections
Now this is pretty neat and something fun and useful for us tech nerds out there. GliderThrow is a small electronic device that you attach to your control surfaces to measure and set the surface deflections. It can measure in degrees or millimeters with a resolution of 0.1 degree variance. You can even measure differential settings with it because there are two sensors.
The sensors attach to your control surfaces with magnets and you'll then use a dedicated mobile device app to view the screens and measurements in real time. It should make programming simple, fun and accurate.
Check out GliderThrow Here
Dec 13, 2018, 10:59 AM
Scale Aircraft = Scale Crators
mikejr83's Avatar
I WANT ONE!!!
Hey, Santa! This would be a great stocking stuffer.
Dec 13, 2018, 11:07 AM
32.4316 N, 80.6698 W
how heavy are the sensors?
Dec 13, 2018, 01:25 PM
B for Bruce
BMatthews's Avatar
I'm curious on the cost as well. I can see this being an extremely valuable tool for those with serious contest models. Particularly the models that use all four wing surfaces in full span camber change mode to trim the airfoil for optimum performance at each of three or four specific speed settings for min sink, best L/D, Speed and More Speed. The use for these goes way past "just setting the angles".
Dec 13, 2018, 02:07 PM
mikejr83's Avatar
Just got an email from Marco.
The sensor weight including the magnetic peg is 25g
GliderThrow price is 120€ + Shipping.
I'll be ordering a set!
Dec 13, 2018, 03:19 PM
Bad command or file name
Imageek2's Avatar
That's cool!
Tom
Dec 13, 2018, 08:13 PM
Balsa breaks better
Thermaler's Avatar
$64,000 question, how does one get one?
$2 question, how much to get one to 49107?
Joe
Dec 13, 2018, 10:42 PM
There's an email address in the text that goes with the video linked from the web page. Something like [email protected]
Might be worth having if it's inexpensive.
Dec 13, 2018, 11:48 PM
Aka... Chris Graham
NutBag's Avatar
Yep, 120 Euro plus shipping.
Currently on Backorder until early in new year + shipping times
Looks like a great tool to have in the kit for all types of models, not just gliders... I'll definitely be getting a set.
Latest blog entry: Build Pics
Dec 14, 2018, 06:49 AM
founder of the SSP
Steve Boone's Avatar
I use this: https://www.towerhobbies.com/cgi-bin...?&I=LXHDCA&P=7 . I don't care if it talks to my phone.
Dec 14, 2018, 07:18 AM
ltc
ltc
AMA 97737
ltc's Avatar
I use a similar product from Sandor at Digitech
http://www.digitech.nl/at-wizard
Which was just replaced by this one (has built in battery):
http://www.digitech.nl/at-wizard-20-new
Available direct or here in the USA from Danny at Aeropanda.com
https://www.aeropanda.com/collections/digitech
Dec 14, 2018, 07:48 AM
mikejr83's Avatar
How does that hold on to the control surface? I also wonder how well that could be used on a DLG. The GliderThrow are said to weigh under an oz (25g) which should be light enough to not overdrive those small servos.
Very cool. Is there a thread you can link that shows their use? From aeropanda's site it seems like you just hold them to a surface. I'd like to see how they mount.
Dec 14, 2018, 08:17 AM
Closed Account
Joe
I have their GliderCG presently on order. I think that you will actually order from:
https://mahmoudi-modellsport.eu/glidercg (scroll down for throw device)
I believe all the body components are 3D printed so I suspect that these are pretty much made to order. I know I had to wait for my GliderCG to
be printed. There is another brand of CG from I think Spain and they 3D print their gear as well.
The German reviews on the GliderThrow and the GliderCG are all very good.
Dec 14, 2018, 08:56 AM
ltc
ltc
AMA 97737
ltc's Avatar
Don't know of a video.
They are 3d printed and very light (since the battery is external on the original units)
I use thin 3m double sided tape to hold it in place.
You download the app and it just works straight away with your phone or tablet over Bluetooth.
I've used them on F3A planes and also turbine jets. Very nice little unit. Much lighter than my Wixey or Robart or Hangar 9 gauges that I used before.
Dec 14, 2018, 10:41 AM
Alt + 24 = ↑ & Alt + 25 = ↓
Miami Mike's Avatar
I use this...
I use a similar product...
I was hesitating at first but I guess now it's okay to show our alternate, cheaper solutions.
I use these:
Discussion Control surface throw measurement randall_l Hand Launch 7 Nov 05, 2017 03:32 PM
Discussion Control Throw Measurer? CC268 3D Flying 25 Dec 02, 2015 07:18 PM
How do you Measure control surface throws buzzbee Beginner Training Area (Aircraft-Electric) 5 May 27, 2004 08:00 PM
Measuring control surface throw msp1957 3D Flying 3 Dec 01, 2003 08:30 AM
Control throw measurement ToddO Parkflyers 2 Feb 17, 2003 07:09 AM
