Chair-Pak's FPV Pak Add-On is Here
The long awaiting add-on for the Chair-Pak is finally here with the FPV Pak insert.
Get Your FPV Add-On for Chair-Pak
A couple of years ago I reviewed the Chair-Pak and still use it to this day. It's a chair attached and part of a backpack that you can fold up and carry on your back with all of your FPV gear and drones and it is the ultimate in convenience. There are lots of backpacks out there for drones, but none of them provide a chair or the features that you get with the Chair-Pak.
When I got mine in 2016, the backpack portion was just an open space with several compartments, but the designer was also working on an insert for FPV specifically that would securely store and protect your gear. There's also been some great changes to the design to allow drones to be attached to the outside and while it took awhile, the FPV Pak insert is finally here and it's available for $79.
Check out the Chair-Pak Here
Check out the FPV Insert Here
