This thread is privately moderated by TinkleWid, who may elect to delete unwanted replies.
Dec 08, 2018, 11:25 PM
TinkleWid's Avatar
Cool
Caddx Turtle v2 🐢 SLOWMO Settings 🦕 3" HGLRC F440 👻 Lucky Day !!
A bit of luck is always needed when racing through those first 'GHOST' Branches 👻👻👻👻👻
Caddx Turtle v2 🐢 SLOWMO Settings 🦕 3" HGLRC F440 👻 Lucky Day !! (2 min 15 sec)
Equipment Used:
Flying the Kwad Karl (Bando Racer 3) BR3 Frame
XJB 145 build and motors https://www.banggood.com/HGLRC-Flame...18277502201801
Caddx Turtle v2 with v2 firmware https://www.banggood.com/Caddx-Turtl...18277502201801
XM+ https://www.banggood.com/Frsky-XM-Mi...18277502201801
VRD2 Pro Goggle
Jumper T8SG
Gemfan 3052 https://www.banggood.com/2-Pairs-Gem...18277502201801
🐢 🐢 🐢 December 2018 Edit 🐢 🐢 🐢
I have been sent a COUPON CODE for the following products: (508fd3 @ 10% off)
Caddx MB05 Main Board PCB Mini Camera Module for Turtle V2 (508fd3)
https://www.banggood.com/Caddx-MB05-...stlinkid=72553
Caddx CM07 Camera Protective Case Set OSD Board Bracket AV Cable for Caddx Turtle V2 Black/Red - Red https://www.banggood.com/Caddx-CM07-...stlinkid=72555
Caddx MB05-2 1/2.7 CMOS 800TVL Sensor Board Camera Module 1080P 60fps WDR for Turtle V2
https://www.banggood.com/Caddx-MB05-...stlinkid=72558
Caddx MB05-1 1080P Mini Recorder Board DVR Camera Module https://www.banggood.com/Caddx-MB05-...stlinkid=72559
RUNCAM COUPON CODES ( 508fd3 @ 10%)
RunCam Split Mini 2 FOV 130 Degree 1080P/60fps HD Recording & WDR
https://www.banggood.com/RunCam-Spli...stlinkid=72560
RunCam Split 2S FOV 170 Degree Super WDR Mini FPV Camera 1080P 60fps DVR HD Recording OSD for RC Drone
https://www.banggood.com/RunCam-Spli...stlinkid=72561
RunCam PLA Bracket Fixed Mount Holder For Runcam Split Mini FPV Camera
https://www.banggood.com/PLA-Bracket...stlinkid=72562
RUNCAM COUPON CODES ( 105ea3 @ 15%)
RunCam 2 RunCam2 HD 1080P 120 Degree Wide Angle WiFi FPV Camera
https://www.banggood.com/RunCam-2-Ru...stlinkid=72563
Caddx Turtle Settings: 1080p 60FPS
Wide FoV
7 saturation
1 Sharpness
5 Contrast
5 Brightness
EV -0.3
WDR on
SLOWMO set to 40%
Go Pro Lens (if you have space in the frame) https://www.banggood.com/SHOOT-170-D...r_warehouse=CN
caddx turtle v2 vs runcam split mini 2
Caddx Turtle V2 is NOT ALWAYS SHIPPED WITH THE LATEST FIRMWARE 😱😱 Don't forget to update your firmware 😱😱
Tutorials and Links:
How to repair a bricked Caddx Turtle from a firmware update
http://www.multirotorguide.com/guide...rmware-update/
September Firmware - works with v2 and soon to be tested with v1 board https://www.rcgroups.com/forums/show...5&d=1541439082
How to update Caddx Turtle firmware (step-by-step):
"https://www.youtube.com/watch?v=Sh9IAxRsw2E"
LUNCHBOX FPV
I think this footage is better than any Runcam Split Mini 2 footage I have seen and almost as good as a Go Pro.
Best firmware versions dated 7th September 2018
Runcam KILLER 🐢 UPDATED Caddx Turtle v2 Latest Firmware AMAZING 🐢 RunCam Split Mini 2 FPV is DEAD (3 min 37 sec)
Cons:
The lens is still plastic but has been upgraded from v1. We shall have to see if it lasts longer than the first and not pick up any scratches. I am also getting annoyed about the random spots on the camera sensor which I may try to clean. My first camera picked up a small fragment of dust without me opening the lens case. I think the camera is not 'finished' properly so small fragments can come loose in time. I hope a blow of compressed air will clean the sensor?
Caddx Turtle Comparison Lens Test
Smooth 🐢 Caddx Turtle v2 Firmware Update (1080p 60FPS) on BR3 3" HGLRC XJB 145 Quad (2 min 9 sec)
Jan 05, 2019, 06:48 PM
Where is the best place to keep informed about updates for the caddx turtle v2?
Jan 06, 2019, 05:15 AM
TinkleWid's Avatar
I am not sure there will be any updates as the camera is pretty stable now. However, there is a facebook group for Caddx Cameras that may be of use. The Caddx website unfortunately is probably the last place to look
