This thread is privately moderated by marksp, who may elect to delete unwanted replies.
Dec 08, 2018, 10:19 PM
Prefers radials
marksp's Avatar
Hangar 9 XCub 60cc
Virtually the second this plane was announced, I jumped on the pre-order list! Big bush plane - yes please! Being from Pacific Northwest, I’m very partial to bush planes and have thoroughly enjoyed the Hangar 9 1/4 scale P/A-18 Super Cub (both gas & EP), Hangar 9 DHC-2 Beaver (gas & EP) and the 1/5 scale Carbon Cub (gas).
Most of the build list went together quickly and includes:
- Servo (aileron/Elev/Flaps): Savox 1258TG
- Taildragger RC servo extensions
- Rudder: Hitec HS-7956HR
- Rudder: Savox 1231SG
- LED system: Electrodynamics (Nav/anti-collision, wig/wag landing, beacon)
- IFlytalies instrument panel
- PR Bushwheel struts
- PR Bushwheel 8.75” (222mm) Tundra
- Air Top 200mm (7.87”) Tundra - Summer tires
- Jeti Duplex R10 Rex Assist
- Jeti Duplex Dual Mag Switch
- Jeti Central box 200
- (2) Jeti Duplex EX R3/RSW 2.4GHz Receiver
- Jeti Duplex EX R3 REX 900 MHz Receiver
- Jeti Duplex R7 Rex Assist
The hard part was power selection. Spent the better part of 2 months going back & forth between short list:
1. Saito FG-61TS
2. EME 70 twin w/auto-start
3. 12S EP setup
Finally pulled the trigger on the Saito...beautiful engine although twice the price of the 2-stroke gas and EP. Should sound more scale which is important to me :-)
Now that the engine is sorted, added a few things to the list
- RotoFlow - 16 ounce
- Tech-Aero Ignition BEC
- JC Super XCub prop
Let the build begin!
Dec 08, 2018, 10:24 PM
Prefers radials
marksp's Avatar
Components starting to arrive...
Engine - Saito FG-61TS
Servos -
PR Bushwheel XCub struts (left)
Dec 08, 2018, 10:33 PM
Prefers radials
marksp's Avatar
Let the stripping begin!
It’s always hard to tear into perfectly good covering...on the other hand it’s also hard to have a couple of thousand dollars in a model have it looking crappy after a few hours in the sun...and also have it look identical to the next guy with the same kit!
Let ‘er rip...
Dec 08, 2018, 10:41 PM
Prefers radials
marksp's Avatar
LED test
Wanted to check intensity level difference between the stock and the Electrodynamics landing lights. Setup:
- Electrodynamics controller
- Pulse light adapter (wig-wag )
- LiFe 2S
- The ED light is in their hi-intensity lens cover
The ED lights are much, much brighter on 2S. The stock lights are rated for 3S, but no nav, strobes and no wig-wig so I ditched the stock lights and re-wired the ED kit per full scale:
- nav
- anti-collision strobes
- beacon
- wig-wag landing
All controlled by ED controller with landing lights on seperate channel
Dec 10, 2018, 10:09 AM
Prefers radials
marksp's Avatar
Prep
all wood sanded, cleared (4 times) - ready to cover :-)
landing gear fairings scuffed and ready for primer
Dec 10, 2018, 10:10 AM
Prefers radials
marksp's Avatar
Rib stitching ready for cutting
Dec 10, 2018, 10:16 AM
Prefers radials
marksp's Avatar
Let the covering begin...
Dec 10, 2018, 10:43 AM
Prefers radials
marksp's Avatar
Landing gear, wheel & tire weight analysis
Plan is to go with the PR Bushwheel spring setup on this model.
Wanted to weigh diff between the stock setup and the PR Bushwheel so I can sort out CG issues (size of batteries, tank, placement, alum spinner, etc.)
Stock:
Sprung gear assembly:
PR Bushwheel 8.75" wheels & tires
PR Bushwheel struts & axles:
r
Dec 10, 2018, 02:15 PM
Prefers radials
marksp's Avatar
Covered!
Dec 11, 2018, 07:45 AM
Prefers radials
marksp's Avatar
wings covered!
Dec 12, 2018, 07:44 AM
Prefers radials
marksp's Avatar
Faux rib stitching applied :-)
Dec 12, 2018, 07:52 AM
Prefers radials
marksp's Avatar
Signature X Glacier
Selected from the XCub configurator tool (www.cubcrafters.com) -
Using all PPG automotive paints
1. Tesla White Pearl metallic
2. Lexus Graphite (black) metallic
3. Toyota Blue
4. Lexus Silver metallic
Dec 18, 2018, 11:39 PM
Prefers radials
marksp's Avatar
Fuselage covered! :-)
Dec 20, 2018, 09:59 PM
Prefers radials
marksp's Avatar
Doped and ready for primer...
Nitrate dope (clear) applied and drying.
Dec 28, 2018, 10:25 AM
I just found your build blog on this aircraft and I'm along for the ride..
Nice work..
Tom
Discussion Hangar 9 CubCrafters XCub 60cc ARF Jeepworld2002 Giant Scale Airplanes 507 Dec 27, 2023 04:33 AM
Discussion Hangar 9 60cc P-51 retract options Zman39 Giant Scale Airplanes 4 Jan 09, 2019 08:15 PM
Discussion Horizon CubCrafters XCub 60cc ARF (HAN5260) PookaHat Giant Electric Planes 9 Sep 26, 2018 07:06 PM
Help! New to large scale, need help/info/pointers (CubCrafters XCub 60cc ARF) Patriotic_Banana Giant Electric Planes 27 Jun 10, 2018 02:56 PM
Discussion corsair 60cc hangar 9 jackson2323 Giant Scale Airplanes 0 Dec 27, 2015 07:24 PM
