Feb 26, 2020, 08:09 AM
Originally Posted by Garysnr
If anyone is looking to buy this tablet, it's on sale for $91.99
using coupon code "BG9e48fc" at Banggood
https://www.banggood.com/Teclast-M89...p-1484082.html
Thanks for sharing but be aware this is the "Pro" version and does not have HDMI-out like the M89 most of us use here !
Feb 26, 2020, 08:11 AM
Originally Posted by C0cKPitVuE 777
The motors do get hot,I've reported this in earlier posts,not so a standalone case,in fact one of my motors are becoming dislodged and unmounted,thank God I noticed it before I lost in in flight.To be fair it always happens in temps above 50 degrees Fahrenheit.It has always been an issue with me,now I can't get the arm off,the torque head is stripped.
They get warm on normal use, I would not say they run to hot in general. (just from feeling, I have not measured temps)
Your dislodging is rather strange... besides that, can you point to other reports other than Dyna with motor problems?
If not I say it's still a standalone case.
Feb 26, 2020, 08:12 AM
Originally Posted by aiolosimport
FIMI stated to keep motor temp. below 70C degree to avoid motor failure.
In my X8’s flight, in summer time, motor temp. raised over 40C degree after flight and some over 50C.
The hottest temp after flight was 63C degree on front left motor on Aug 8.
On this flight, I did very aggressive flight (full aileron sideway flight to check gimbal horizon level) with 16m/sec and two consecutive flights for total 15min.
During the sideway flight Gale, Overload warning popped up.
Ground temp. was 26.0/29.5C before/after flight.
Temp. record before/after flight is attached below.
If I did continuous flights say 6 batteries without cooldown or only 3-5min which is not enough to reduce temp unless you use cooling fan (done by someone to show motor failure and crash), I believe motor temp would be accumulated and exceeding the max. temp of 70C degree.
If I did this kind of flight almost every day (as some one did), it will surely damage the adhesive of magnet attached to motor case to create stuck the motor even not in summer season.
Timeline for this flight video is;
0:03 Preflight check
0:05 Max. 16.0M/S, Max. Height 60.2m (to use full sideways movement at 60m rather than usual 150m)
0:21 Firmware update FC 1055E
1:13 1st take off 1080P 60FPS
2:33 Full left aileron at Max. 16.0m/s
3:05 Reached 420m left side & Slow left yaw turn
3:40 Full right Aileron at max. 16.6m/s
4:27 Reached 400m right side, slow left yaw turn
4:55 Full Elevator down, Max. 13.9m/sec
5:15 Warning “Gale warning, please fly carefully”
5:18 Warning “Drone overloaded, please fly carefully”
5:27 Speed reduced to 0.3m/sec – Warning disappeared
5:28 Slow left yaw turn
5:56 Check horizon level – keeping horizon, Slow right yaw turn
6:41 Quick left yaw turn
6:45 Quick right yaw turn
6:53 Keeping horizon level
7:02 Auto RTH
7:59 Landing pad detected at 9.1m H
8:25 Landed on the pad
8:44 Video setting change to 2.5K 30FPS from 1080P 60FPS
9:08 2nd take off
10:12 Slow left yaw turn
10:42 Full left aileron turn at max. 16.3m/sec
11:02 Warning “Drone overloaded, please fly carefully” at 300m (approx. 20sec full Aileron)
11:15 Warning disappeared at 495m with 15.4m/sec
11:20 Reached 584m to the left
11:30 Full right Aileron at max. 16.8m/sec
12:30 Reached 295m + 584m = about 879m full aileron for approx. 1min.
12:33 Full left Aileron at max. 16.2m/sec
12:47 Warning “Drone overloaded, please fly carefully” at 94m.
About 490m flight (584m – 94m) abut 1min10sec flight.
12:50 Warning disappeared
12:58 Slow left yaw turn
13:36 Slow right yaw turn
14:27 Quick left yaw turn
14:07 Quick right yaw turn
14:14 Keeping Horizon level
14:21 Auto RTH
15:21 Landing pad detected at 8.6m H
15:29 Landed on the pad
https://youtu.be/lJnpeLYZfCE
Temp. record before/after flight is attached.
https://docs.google.com/spreadsheets...6lg/edit#gid=0
Aiolosimport
Excellent test as always Aiolosimport!
Feb 26, 2020, 08:25 AM
2Doggs's Avatar
70c seems pretty low, only about 30 degrees above ambient in the summer here down South. I've had heli motors that get to about 130c with no problems.
But that would definitely suggest it's good practice to allow the motors to cool down after each flight.
Feb 26, 2020, 08:40 AM
I can easy sit 10 to 15 minutes in a sauna 90/100c - if I do that 6 times with 3min pause I'm dead
Feb 26, 2020, 09:52 AM
Like you I have the earlier version but don't use the HDMI feature, and as it's a bit cheaper than mine I thought I'd post the link.
Feb 26, 2020, 10:02 AM
I think the temperature recommendation for the motors has to do with the magnets used rather than the glue used to fix them.
https://www.first4magnets.com/tech-c...um-magnets-i91
I found this in a quick search for max temperature in neodymium magnets.
Feb 26, 2020, 12:23 PM
Not crashing = Not flying!
Originally Posted by vbSAGE
Its not held on (maybe in another version soon). It is just a podium to launch from and keep gimbal well clear of the ground.
Well that's not acceptable lol, thanks.
Feb 26, 2020, 12:53 PM
Mavic Air 2 World Domination
Windy Heap's Avatar
Can't believe people are getting to the point of worrying about melting point of magnetic properties.
but if being microscopically-anal about it, just get a non contact IR temp gauge if that floats your boat, or better yet a Type J or K thermocouple with onboard digital LED display instrumentation mounted on drone.
shrug.
https://www.banggood.com/BENETECH-GM...r_warehouse=CN
Feb 26, 2020, 01:52 PM
It's just a bug...
alambik's Avatar
Did you had crash with your drone? Is it the same on the 4 rotors?
I've got such disloged/dismounted motors problem like on the picture: it's the torsion that provocated the pin distortion under the rotor. It was after a crash I had by my fault. I changed the arms, and no problem.
I can't imagine heat would alter the pin. But since now I have arms spare, I can do some stress test heating them to see if any problem occurs.
Feb 26, 2020, 02:00 PM
It's just a bug...
alambik's Avatar
Arm repair quotation
I just receive another quotation for repairing X8 arms. I had 2 arms to repair.
Although it's already done, here are the price for your reference:
Code:
- FIMI X8 SE original replacement arm with motor - 29,90€ (2x)
- FIMI Repair Center - Labor Costs - 59,00€
- DHL Shipping - 13,90€
All prices incl. 19% VAT
Aeromey GmbH
Branch FPV1.DE
Berliner Ring 95
64625 Bensheim
Germany
phone: +49 6251 82559 11
web: FPV1.de
email: info@fpv1.de
Feb 26, 2020, 04:17 PM
unionglzr
just flew mine the other day 50-55F the motors werent even warm so take certain individuals comments cautiouslyas there is an agenda to them
Feb 26, 2020, 04:48 PM
Thanks for your correction. It explaines well.
My comment was based on the experence of brushless motor mounted on RC airplane which had problem of peeling off of magnet after repeated flights without cooling down of each flight.
Aiolosimport
Feb 26, 2020, 04:50 PM
Mr
vbSAGE's Avatar
Launch Tower
Originally Posted by Kaptor
Hey how is that held on? Is it possible to flip it upside down for storage under the X8 in the case?
OK, OK here is version 2. Held on to X8 with a Velcro strap. (am working on a V3 with detachable legs for easy storage)
>>>> USE AT YOUR OWN RISK <<<<
Discussion Official Xiaomi Mi Quadcopter Owners thread DumbthumbsFPV Multirotor Drone Talk 11043 Aug 15, 2023 04:01 PM
New Product XIAOMI MIJIA 4K - AMB_A12 + IMX317 - Gyro,Display 2.4'', Wi-Fi,BTH, **Owners Thread Marcofan76 Aerial Photography 104 Apr 26, 2020 09:18 AM
New Product Xiaomi FIMI A3 5.8G FPV 2-axis Gimbal 1080P Camera GPS Quadcopter - Free Reviewing BGKevin Multirotor Drone Talk 68 May 25, 2019 12:36 PM
Discussion Official DJI OSMO ****Owners Thread**** eirlink Aerial Photography 2221 Jan 29, 2019 07:31 AM
Discussion Xiaomi FIMI 4K Folding Drone GeekBuying Vendor Talk 15 Dec 29, 2018 04:25 AM
