This thread is privately moderated by Jim.Thompson, who may elect to delete unwanted replies.
Dec 02, 2018, 03:37 PM
Entropy is happening!
Jim.Thompson's Avatar
My silicone hinge video
Link to the vimeo video here:
(8 min 19 sec)
Feb 21, 2019, 10:25 AM
High-power Rocket Gliders
iter's Avatar
Wow! This is so simple. I'm naturally lazy. I love this simplicity! What the largest model you used this on? Some of your larger models have tube hinges.
Ari.
Feb 21, 2019, 10:28 AM
iter's Avatar
Ari.
Feb 21, 2019, 03:39 PM
Originally Posted by iter
Wow! This is so simple. I'm naturally lazy. I love this simplicity! What the largest model you used this on? ...........
The largest is 2 mtrs. It is very simple to do actually.
Ari.
Yes Ari. Or more accurately, they have pocket hinges. Lot of work!
Thanks for the reply.
Jim.
Feb 21, 2019, 03:52 PM
iter's Avatar
You mention DS in your video. Is there any setup outside of that where you'd recommend against silicone? Does it have to be foam core, or do these hinges work on less-porous materials?
Ari.
Feb 21, 2019, 03:57 PM
You mention DS in your video. Is there any setup outside of that where you'd recommend against silicone? ............
I have used them on a variety of models. All types.
Ari.
Not at all. Foam core has nothing to do with their suitability for a hinge. I use them on a fully composite hollow moulded wing to replace torn kevlar hinges, for example.
Feb 21, 2019, 06:07 PM
iter's Avatar
This opens up so many possibilities.
Feb 21, 2019, 07:17 PM
I have yet to find a construction material that it will not work with.
When using it against a wood drag spar and control surface leading edge spar, I paint the wood with epoxy and allow to cure first, then run the hinge. CA also works for this.
