This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Nov 28, 2018, 09:09 AM
Mini-Review
Frsky Taranis X-Lite R9M Lite Long Range bundle
Frsky Taranis X-Lite 2.4G 16CH Transmitter with Hall Sensor Gimbals Mode 2 + R9M Lite + R9 Mini Receiver
Cool the long range version.
130€ Flash Deal
Package Contents:
- X-Lite Transmitter
- R9 Mini Receiver
- R9M Lite Module
The X-Lite is the new version with two more screws at bottom.
With the bundle you get the R9 Lite long range module with the standard elastic antenna. Better you get the FrSky Super 8 antenna for the module for better range.
The very small R9 MINI receiver have only a non inverted output for telemetry. If you have a F3 or F4 flight controller then it is better to get the newer FrSky R9 MM receiver.
The new R9 MM receiver looks the same as the old version R9 MINI but the new have a non-inverted telemetry output tu connect to a free TX port on your FC. For more better range you can use the new FrSky Dipole T Antenna on your 4-6 inch FPV racer drone.
Link - Taranis X-Lite with R9M from Gearbest
My video (EN subtitle) - Taranis X Lite german EU Firmware with R9M Lite 900MHz Module
Taranis X Lite deutsche EU Firmware mit R9M Lite 900MHz Modul (4 min 8 sec)
Link - FrSky R9 MiNI receiver from Hobbyking for only $9.50
Link - FrSky R9 MiNI receiver from Gearbest Coupon: SWwOx6Jg:
FrSky R9 MM receiver from Banggood Coupon: TTxBG10
Link - FrSky 900MHz Super 8 Antenna for R9M / R9M Lite Module from Banggood Coupon: TTxBG10
Link - FrSky 900MHz Dipole T IPEX4 Receiver Antenna for R9 Mini / R9 MM from Banggood Coupon: TTxBG10
2 PCS 3.7V 1500mAh 18500 Li-ion Battery for Frsky X-Lite Radio Transmitter from Banggood
IRangeX IRX4 LITE CC2500 NRF24L01+ A7105 CYRF6936 4 IN 1 Multiprotocol TX Module for Frsky X-lite from Banggood
FrSky Taranis X-Lite Transmitter Spare Part BRACE Lite & Long + Short Gimbal Stick Ends
Aug 22, 2019, 02:55 PM
Multi-Protocol Module and Brace together?
Does the Multi-protocol Module fit with the brace also fitted ?
Discussion FrSky - New - Taranis X-Lite - S and Pro - X9 Lite - R9M Lite and Pro - MPM Lite Jet_Flyer Radios 3326 Today 12:21 AM
Discussion FRSky R9M Lite - Long range mini module for Taranis X-Lite sevet Radios 40 Jun 26, 2019 02:21 AM
