This thread is privately moderated by guldukat, who may elect to delete unwanted replies.
Nov 26, 2018, 06:33 AM
Trader Rating: 13
guldukat's Avatar
$50.00 USD
Seller Pays Shipping
Sold
Bluebird brushless BLS-42A Servos - Torque At 8.4V 47.5 kg-cm / 659.8 oz-in
50.00 each - total 8 pcs available.
Takes off a AJ Laser 105 after appx. 20-25 or so flights. Sold the AJ Laser last week.
Specs:
Specifications
Torque At 6.0V 32.9 kg-cm / 456.9 oz-in
Torque At 7.4V 42.1 kg-cm / 584.8 oz-in
Speed At 6.0V 0.12 sec / 60
Speed At 7.4V 0.10 sec / 60
Speed At 8.4V 0.09 sec / 60
Power Supply
Operating Voltage Range 6.0V ~ 8.5V ( 5 ~ 6 Cell Ni-MH or 2S Li-Poly / 2S Li-Fe )
Standard Full Aluminum Servo
Control System Digital Controller / 12-Bits ( 4096 Steps )
Dead Band Width 0.001ms ( 1us )
Mechanical Specifications
Ball Bearing Dual
Gear Titanium Alloy Gears
Motor Premium Brushless Motor
Horn / Gear Spline 25 Teeth ( Same as F-Type )
Physical Specifications
Dimension (mm) 40.5 x 20 x 39 mm / 1.59 x 0.79 x 1.54 in
Weight (gram) 81.5 1 grams / 2.87 oz
https://www.blue-bird-model.com/products_detail/43.htm
Sold Bluebird BLS-42A Servos - Torque At 8.4V 47.5 kg-cm / 659.8 oz-in guldukat Aircraft - General - Radio Equipment (FS/W) 7 Nov 23, 2018 07:33 AM
New Product Stall Torque (7.4V): 65kg.cm -- newly big torque servos LANI Product Announcements 0 Nov 22, 2016 04:10 AM
Sold BLS-2112 Wide Voltage (4.8~7.4V) Brushless Digital Servo w/Titanium Alloy Gear skippykix Aircraft - General - Radio Equipment (FS/W) 0 Oct 14, 2016 07:36 PM
Sold MKS HV777 Aluminum upper Casing (0.1 sec/60 - 38.00 kg.cm (520 oz/in) @8.2V) ibcinyourc.com Aircraft - General - Radio Equipment (FS/W) 0 Sep 26, 2015 10:24 AM
Discussion Servo torque conversion kg/cm to oz. Backwing Radios 13 Oct 18, 2007 06:15 PM
