Nov 21, 2018, 04:59 AM
New Product
Eachine TX806 leaf 5.8Ghz 72Ch FPV Transmitter Smart Audio MMCX MIC -- Free Reviewing
New product needs reviewed.
Eachine TX806 leaf 5.8Ghz 72Ch 25mW/200mW/400mW/800mW/1000mW AV FPV Transmitter Smart Audio MMCX MIC
5 - 6 Quotas for free testing.
Check the link here: Eachine TX806
Pit mode(0.01mW) :
While the VTX is pit mode, the LED shows "P" and flash.
While in pit mode, you can switch channels and set power levels, but none of these changes will take effect until you quit pit mode. By default, pit mode will send a veru weak signal
Features
Support smart audio
25mW/200mW/400mW/800mW/1000mW power switchable
One key searching and power setup
OSD configuration using smart audio
Wide input voltage with 5V for camera
72 channels with MIC
Solid MMCX antenna connector and rp-sma pigtail cable
Digital diaplay
Description
Brand name : Eachine
Model : TX806
Input voltage : 7v to 25v
Output voltage : 5v camera supply
Working current : [email protected];[email protected];[email protected];[email protected];[email protected]
Extra feature : smart audio
Output Power : 25mW/200mW/400mW/800mW/1000mW switchable
Antenna connector : MMCX
Cable : JST-SH 1.0mm 6P
Dimension : 50mm*28mm*5mm, 43 stackable hole
Weigth : 8.8g(excluding antenna)
Operation
Channel Select
Select channels by simple short presses, by ordinal display for channel(CH:1 2 3 4 5 6 7 8)
Band Select
Press button for 2s, LED will flash, then short presses to select band (Band: ABEFRUOLH)
Power Select
Press button for 4s, LED will flash, then select power by simple short press
"1" stands for "25mW"
"2" stands for "200mW"
"3" stands for "400mW"
"4" stands for "800mW"
"5" stands for "1000mW"
The LED will display "channel" "band" "power" sucessively after setting.
Note: LED flash 2 times quickly while displaying power ,eg, "1" flashes 2 times means "25mW"
Nov 21, 2018, 05:00 AM
Res
Nov 21, 2018, 08:34 AM
angelo.p's Avatar
Great! 1000mW with only 8.8g!
I would to test it if possible
Nov 21, 2018, 04:47 PM
I assume those holes are for mounting the VTX on the 30.5x30.5mm stack?
Does it provide real 1000mW?
But anyway it is the weirdest shaped VTX on the earth!
Nov 21, 2018, 06:05 PM
Bring it Down!!
FlightCrazed's Avatar
This would be great for my 48" seniorita scratch built fpv bird. I'd be up for reviewing this one.
Nov 22, 2018, 04:15 AM
Yes, the shape is uncommon.
Nov 22, 2018, 11:11 PM
I would like to test it, SMA Version
Nov 23, 2018, 05:46 PM
This is one strange looking VTX
Nov 24, 2018, 03:23 PM
Would also test (SMA version) on my new dart xl in long range situation. Have some other VTX to compare:
-TX5258
-TX805
AKK X2 ultimate
Nov 25, 2018, 06:50 AM
Thijs rc
thijs slotman's Avatar
i would love to test it in my newest build.
the sma male version would be nice i have done multiple reviews on fpv cams and vtx.
Nov 25, 2018, 10:29 AM
I would like to test it!
Very uncommon shape and very interesting features, power output first of all
Nov 27, 2018, 05:13 PM
dagob's Avatar
I already reached 8.3km with the Eachine tx805, but looking for a new vtx to get me further I found this Eachine TX 806 on Banggood rated at 1W power , and very good price too! I'd like to test it on my long range C1 Chaser to see if I can get to 10~12KM.
Dec 07, 2018, 03:25 PM
Fan of just about anything RC
SoloProFan's Avatar
If there is still a spot open, I'd like to try one.
Latest blog entry: For the love of the hobby!
Jan 20, 2019, 04:56 PM
Eachine TX806 Leaf Mini-Review
Package contents
TX806 comes with a VTX, MMCX linear dipole antenna, MMCX to RP-SMA or SMA adapter pigtail (can be selected on purchase), cable with 6pin 1.0mm JST-SH plug and a small instructions leaflet.
TX806 has MMCX antenna connector and 7-segmet LED for channel, band and power output status display. One push button for setting the Channel, Band and power output level.
VTX weight without cables and antenna is 8.7 grams
The shape of the VTX reminds me something...
Eachine TX806 can be mounted on the stack – two holes align diagonaly with stack opposite corners.
Here are the measurements table and the graph of the TX806 power output test:
Power output linearity on the Raceband channels with 25mW, 200mW, 400mW, 800mW and 1W setting:
So pretty impressive power output on 1000mW setting.
Full review is here: https://www.rcgroups.com/forums/show...er-output-test
Discussion Free Test - Eachine TX5258 5.8G 72CH 25/200/500/800mW Switchable FPV Transmitter BGKevin FPV Equipment 61 Jun 06, 2020 10:00 AM
New Product Eachine ATX03 Mini 5.8G 72CH 0/25mW/50mw/200mW Switchable FPV Transmitter-FREE TEST BG Tobey FPV Equipment 71 Mar 16, 2019 07:15 PM
New Product RMRC Cricket Pro V2 - 5.8GHz VTX with Smart Audio - MMCX jaganfpv Product Announcements 3 May 08, 2018 08:03 PM
