This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Nov 20, 2018, 11:24 PM
Merch's Avatar
Mini-Review
Happymodel Mobula7 Whoop Review With Mods
https://www.banggood.com/Happymodel-Mobula7-75mm-Crazybee-F3-Pro-OSD-2S-Whoop-FPV-Racing-Drone-w-700TVL-Camera-BNF-p-1357971.html
If your mobula 7 drops out the air when near you try binding up the quad up in D8 mode.
Specification:
Brand Name: Happymodel
Model: Mobula7
Item Name: 75mm Wheelbase 2S Brushless Whoop FPV Racing Drone
Wheelbase: 75mm
Version: Basic Version / Standard Version ( Optional)
The diffirence of them are the package charger.
Basic Version: USB Charger
Standard Version: 6-way Charger
Receiver ( Optional): Compatible Frsky NON-EU Receiver
Compatible Frsky EU-LBT Receiver ( XM+ Receiver)
Compatible Flysky AFHDS/ AFHDS-2A Receiver
Compatible DSM2/DSMX Receiver
Weight: 25.9g (without battery)
Crazybee F3 Pro Flight Controller Item Name: Crazybee F3 Pro FC
MCU: STM32F303CCT6 (72MHZ, 256K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Power supply: 1-2S battery input (DC 3.5-8.7V)
Built-in 5A(each) Blheli_S 4in1 ESC Dshot600 ready
Built-in Receiver ( Diffirent version having diffirent receiver)
Built-in Betaflight OSD(SPI Control)
Built-in Current meter Max 28A
Current meter scale set to 1175
Built-in 5V 1A BEC with LC filter
Built-in voltage detection
BLHELI_S pass-through Ready
Heading LED Ready
Firmware
(Frsky version) CRAZYBEEF3 PRO FR Firmware target: CrazybeeF3FR
(Flysky version) CRAZYBEEF3 PRO FS Firmware target: CrazybeeF3FS
(DSM2/DSMX version) CRAZYBEEF3 PRO Firmware target: CrazybeeF3DX
(Frsky EU-LBT version) CRAZYBEEF3 PRO FS Firmware target: CrazybeeF3FS
Onboard 5A 4 In 1 ESC
Power supply: 1-2S LiPo/LiPo HV (3.5v/8.7v)
MCU upgraded to EFM8BB21
Current: 5A continuous peak 6A (3 seconds)
Support BLHeliSuite programmable
Factory firmware: S_H_50_REV16_7
Default protocol: DSHOT600
Onboard Frsky NON-EU receiver Version
SPI BUS receiver
Frsky D8/D16 switchable
Compatible Non EU transmitter both D8 and D16 mode
Channels: 8ch or 16ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Onboard Frsky EU-LBT Version
(External XM+ receiver)
Operating Voltage Range: 3.7~10V
Operating Current: 30mA @5V
Operating Range: Full range
With RSSI output on board: Analog 0~3.3V
Firmware Upgradeable, Default firmware EU-LBT with RSSI
Onboard Flysky receiver Version
SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
Failsafe support
Onboard DSM2 / DSMX receiver version
Serial bus receiver
Protocol: DSM2/DSMX compatible
Channels:6-9 (Depend on your radio)
SE0802 16000KV Motor
Model: SE0802
KV: 16000KV
Configu-ration: 9N12P
Stator Diamter: 8mm
Stator Length: 2mm
Shaft Diameter: Φ1.0
Motor Dimension (Dia.*Len) : Φ10.5*14.5mm
Weight: 1.8g
Support 1-2S Lipo
No.of Cells: 1S Lipo
Propeller
40mm 4-blade Propeller ( 4 CW + 4 CCW)
5.8G VTX AIO Camera
5.8G 40CH 25mW VTX
Output power: 25mw
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 300mA(type)
700TVL FOV120 Camera
Camera resolution: 700TVL
Video Format: NTSC
Antenna: RG178 antenna
Frequency: 5.8GHz 5bands 40 channels
With Raceband
Smartaudio ready(Frsky EU-LBT and DSMX version not compatible)
Size: 13.9"12.0mm ( L*W )
Weight: 3g
Lipo Battery
Capacity:250mAh
Voltage:3.8v
Continuous Discharge Rate: 30C
Instantaneous discharge rate: 60C
Weight: 6.5g
Connector: PH2.0
Notes: Need 2pcs batteries for Series circuit
Features:
- New Crazybee F3 PRO Flight controller 1-2s Lipo compatible
- 2S whoop more powerful and more flight time
- Betaflight support , multi flight mode: ACRO/AIR/ANGLE
- New 0802 Powerful and High efficiency Brushless motor and Smooth ESC
- Smartaudio ready , change VTX bands, channels via OSD
DSM2/DSMX and Frsky EU-LBT version are Serial-based receiver, so Smartaudio is not compatible.
- Adjust the settings and the PID of the flight controller via OSD
- Frsky Non-EU version support NON-EU Frsky transmitter D8/D16 compatible
- Flysky version support both AFHDS and AFHDS-2A protocol transmitter
- DSM2/DSMX version support DSM2 and DSMX compatible Spektrum transmitter
- Frsky EU-LBT version support Frsky EU-LBT firmware transmitter
- Full telemetry function ready
- Head lights ready
- Camera angle adjustable
- Real Bind and Fly version
- Buzzer Ready
Package Included:
Basic Version
1x Mobula7 75mm FPV Drone
4x 40mm 3-Blade Propellers ( 4 CW & 4 CCW)
4x 3.8v 250mah 30C/60C Lipo battery
1x USB Lipo/LIHV Charger
1x Fixing Mount for Lipo Battery
1x Propeller Disassemble Tool
1x Screwdriver
Standard Version
1x 1S06 6 Way Lipo/LIHV charger
1x Screwdriver
Nov 21, 2018, 02:55 PM
Merch's Avatar
First mod already done,swaped everything over to the betafpv V2 frame.
Nov 24, 2018, 12:32 PM
Merch's Avatar
Weather is really bad here so no flights or review for now
Nov 27, 2018, 08:52 PM
Merch's Avatar
Just got my 2s nano tech batteries in today will start modding tomorrow,XT30 plug on quad and batts,mod the battery tray and some other things.
If you want a video up without a outdoor flight i can do one,we will have 40+mph winds here
Nov 30, 2018, 01:21 AM
Merch's Avatar
Updated the main post with a mini review frame swap and battery mod video.
Dec 04, 2018, 11:25 AM
Merch's Avatar
Outdoor test flight will be posted when there is a break in this horrible weather.
Jan 01, 2019, 02:36 PM
Merch's Avatar
Upgraded 5.8ghz 40ch 25mw-200mw VTX For the Mobula 7 HERE manual HERE
Feb 27, 2019, 12:36 AM
firewight
How do you attached the new VTX to the existing camera? The old VTX & camera appear to be a single unit...
Ideas?
Discussion Happymodel Snapper7 75mm Crazybee F3 OSD 5A BL_S ESC 1S Brushless Whoop FPV Drone BobFromMars Banggood.com 234 Apr 12, 2019 01:40 PM
Discussion Happymodel Mobula7 75mm Crazybee F3 Pro OSD 2S Whoop FPV Racing Drone w/ 700TVL Camer scousethief Banggood.com 48 Mar 10, 2019 11:28 AM
New Product Happymodel Mobula7 75mm Crazybee F3 Pro OSD 2S Whoop FPV Racing Drone BGjim Multirotor Drone Talk 14 Nov 13, 2018 05:22 PM
New Product Happymodel Mobula7 75mm Crazybee F3 Pro OSD 2S Whoop FPV Racing Drone Cheburator Banggood.com 1 Oct 15, 2018 11:14 AM
