FuriousFPV Smart Cable
The FuriousFPV Smart Cable is a neat little gadget for powering your FPV gear. You can plug in any 3S to 6S lipo battery and get a regulated 8V output. It's perfect for duration flights when normal goggle batteries wouldn't cut it or you have an all day practice session planned.
New Idea for Powering Your Goggles or Ground Station
The FuriousFPV Smart Cable is a neat little gadget for powering your FPV gear. You can plug in any 3S to 6S lipo battery and get a regulated 8V output. It's perfect for duration flights when normal goggle batteries wouldn't cut it or you have an all day practice session planned. The Smart Cable has an OLED display on it that helps you monitor data like time, voltage, current, capacity, temp and more.
There is an easy off button that also cuts power to the fan so you won't forget to remove the balance tap and run your battery down. I get by just fine with a regular goggle battery, but I can see how the Smart Cable would be handy for duration sessions, not to mention the cool factor of having a new gadget to show off. Here's more details on the Smart Cable.
Features:
  • Wide 3S 11.1V - 6S 22.2V Input Range
  • Ultra Convenient dual “Smart” On/Off Buttons
  • Designed for Rapid Battery Swaps
  • Short Circuit Protection Technology
  • Configurable Low Voltage / Over Voltage Warning Buzzer
  • Ultra Clear OLED Display
  • Multi Data Display with Call Sign, Voltage, Time, Warning, Current, Capacity & Temperature
  • Designed to Work with Multiple Goggle Platforms
  • XT60 Input Power Ready
  • Pronged barrel connector for DC output for better connection
  • Balance Wire Protection Clip
  • Ultra Long 125cm Wire Length
Check out the FuriousFPV Smart Cable Here
Nov 20, 2018, 01:22 PM
"Aircraftus Fragmentum"
kydawg1's Avatar
I have one.... works fantastic.
Nov 20, 2018, 06:56 PM
Shifteer's Avatar
Say what you want about these products, but these Furious guys are pretty smart at developing simple things that people need, or didn't know they needed until they saw them!
Nov 20, 2018, 07:43 PM
kydawg1's Avatar
Yep agreed... good stuff.
Nov 20, 2018, 11:26 PM
I have the box style for my crossfire and the cable for my goggles. I have to say they are the best thing ever. I love I can use any battery and it tells me the percentage of the battery. Sometimes I just use it as a battery tester.
Nov 21, 2018, 09:58 AM
Was going to get one...but ended up making my own out of braided usb cable and some jst connections, doesnt have the OLED dongle but was $2 and braiding looks nice. Wanted to see if i really use it much before id buy another widget as theres always another widget in this hobby.....
Nov 26, 2018, 12:31 PM
Hmerly's Avatar
This thing is awesome. I love not having a brick on my temple, giving me a headache. I just keep the battery in my pocket and this just makes things so much more comfortable. I also love being able to use just about any battery I have. Its really genius.
Latest blog entry: My fixed wings
Nov 28, 2018, 10:07 AM
I found the small on/off switch doesn't work the main switch can't get into the programing ?
tony
Nov 30, 2018, 02:32 PM
kydawg1's Avatar
tony
Tony, you saying the small switch does not allow programming like the main switch?
I had not tried that.
Feb 24, 2019, 01:56 PM
So just a heads up.... I have the box style and the cable and the cable setup broke at the small button about maybe at my 20th time using it. They were great and replaced it right away for me. I have used my replacement about 10 times and samething it went out on me again. When I emailed them the first time they knew exactly what the problem was so I assumed I was getting a better replacement. I wouldn't give this products a thumbs up at all. Very disappointed. The box style works great but it's not comfortable on your head unless you upgrade to the fat strap style band.
Feb 24, 2019, 05:10 PM
I have a similar one from Skyward. With switch but no led readout. Works great for me for +3 months now. Cables on mine look more robust than FuriousFPV smart cable, esp. the fan cable.
I like the idea of the led readout info but I might be a bit worried about hitting its aux off button accidently.
https://skywardrc.com/products/fat-c...13461632942146
May 07, 2019, 02:04 AM
Bought 2 of these cables and both are broken after only some times we use them. On both the cable connections on the main unit AND on the upper switch become loose. It´s unbelievable, on the outline of the main unit AND on the in and out of the upper switch its loose. So every single connection is bad. Ridiculous!!
May 09, 2019, 12:23 AM
I'm on my 2nd one. They sent me a free one and that one broke less than 5 uses. It's garbage.... I'll have to take the time and wire a new button or just skip the button altogether. No real need for it since you can shut it off at the box.
Video FuriousFPV Smart Power Case kremerFPV FPV Equipment 5 Apr 30, 2019 06:38 PM
New Product FuriousFPV Smart Cable - Fatshark Button Alternative kremerFPV FPV Equipment 0 Sep 30, 2018 03:14 AM
New Product FuriousFPV LED Strip Smart Controller Board FPV-LSCB For RC Drone Rishi Banggood.com 1 Sep 10, 2018 03:50 AM
New Product FuriousFPV High Performance DVR Module For Dock-King Ground Station Support Smart Aut Rishi Banggood.com 0 Sep 01, 2018 03:08 PM
New Product FuriousFPV Smart Power Case FPV-0384-S For 18650 Rechargeable Batteries Merch Banggood.com 3 Aug 23, 2018 01:01 AM
