This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Nov 19, 2018, 10:30 PM
old4570's Avatar
Happenings - Tuesday 20 Nov 2018
This is not a review !
Came this morning , @ 64mm EDF .
A) There were no screws for mounting the motor to the EDF ??? ( Whats going on Hobbyking )
B) Tightening the blades to the motor shaft , nope .. Really hard to achieve ..
C) EDF body is a little flimsy , you really need the induction lip glued in place ..
D) Vibration ! , traced back to the nose cone ..
3s -
Using my Predator 40A ESC I saw a full 40A and then some at full power ..
It really has some thrust at this power level ..
Thrust starts at about 5A and by the time you get to 10A there is decent thrust .
At 15A the thrust is getting serious .. At 40A the thrust is very impressive to this EDF noob .
At 40A there was no cooking , but there was some warmth ..
2s -
At maximum power I saw some 26A and the thrust was impressive . I honestly dont see why this combo could not work on 2s .. Ok you wont break any speed records but you will most likely not cook anything either and still have decent flight performance . Obviously model weight will dictate performance .
Wow , my first EDF ..
Nov 20, 2018, 07:46 PM
old4570's Avatar
EDF update
I have thread locked everything .
The nose cone was balanced some ( 90% ) . I left a little imbalance so I could rotate the nose cone and use it as a counter balance to get the EDF to run smooth . Even on 2s the RPM range is 25,000 to 30,000 RPM ( potential rpm range ) at full throttle depending on the battery voltage . And in this RPM range the EDF does run smooth . ( Well after some balancing )
I had problems tightening the fan blade to the motor shaft , just kept slipping on the shaft rather than tightening .
Some thread locker on the motor shaft seems to have cured the slipping problems .
At the moment everything seem to be button down rather well , and I did order some cheap models from HK that I hope will EDF successfully . These will be 2s as I don't see the need to run more battery .
Discussion DLG Demo At the 2018 AMA Convention Nov 4-6, 2018 rockbus Hand Launch 5 Sep 30, 2018 10:37 PM
Careful! Will Some Grand Event Happen On Tuesday That Affects Hillary? Broken Wings Life, The Universe, and Politics 1 Nov 08, 2016 04:10 AM
Poll Who are you going to vote for on Tuesday Nov 2, 2010? FireryPhoenix Life, The Universe, and Politics 44 Oct 30, 2010 05:56 PM
Rant Voting day Tuesday Nov 3rd jumpinjo Life, The Universe, and Politics 20 Oct 31, 2009 07:28 AM
