Nov 18, 2018, 08:04 PM
Help!
Bait Boat Electrics Problem
Hi.
I am looking for a solution for replacing the receiver on an Angling Technics Standard Bait Boat.
It has 3 jets. The left and right jets provide forward differential thrust and the centre jet is for reverse, This is all done from a single ESC.
Also the bait doors are operated from a third ESC.
I have tried a Flysky FS-CT6B, using the recommended settings for Differential Thrust but there is some incompatibility.
Would I be advised to replace the setup with individual ESCs ?
The original receiver is a ACOMS 2 channel one which has an added circuit board for this model.
Nov 19, 2018, 04:35 AM
I would expect the Acoms set to be very basic, so the replacement would need to be as basic. It should be a question of figuring out which of the channels on the new receiver correspond to the Acoms ones.
On a 2 channel set, channel 1 is rudder (right stick left/right), 2 is throttle (left stick, forward/back). I would pretend that "channel" was the throttle and 3 the "rudder" on the 2G4 radio. It is very likely that the control board supplied does all the clever stuff, trying to put extra cleverness into the system at the transmitter won't work.
The two radios should give very similar outputs, so anything that plugs into one and works should work the same in the other.
Build Log Another bait boat project silviuog Dock Talk 2 Oct 19, 2016 01:33 PM
Discussion need help ,scratch build ,fishing/bait boat ccfly Racing Boats - Electric 0 Oct 19, 2016 11:24 AM
Help! Building a bait boat/raft motka Dock Talk 11 May 08, 2016 04:59 AM
Help! Electronics for a boat 2x 380 (bait boat) papiskmuse Racing Boats - Electric 2 Jan 28, 2010 05:44 AM
Help! Electronics for a boat 2x 380 (bait boat) papiskmuse Power Systems 7 Jan 27, 2010 06:32 PM
