Nov 18, 2018, 03:01 AM
maxray1's Avatar
Quadra? Size?
Hi Guys,
I bought this vintage Nosen Mr. Mulligan off Craigslist. It appears to me that it has a Quadra engine but I cannot tell
what size. Anybody have an idea? That's a 20" prop.
Thanks guys.
Nov 18, 2018, 04:10 AM
Bellanca Kruesair
epoxyearl's Avatar
I'm not familiar with Quadras larger than the family of 35's through 42's. But I know they all have rear exhausts...Yours, with the side exhaust ,could be a 50 cc engine..?
Also, take care of that box...There are collectors who cherish them, and they're worth around $25...I sold the container for Sterling's Chris Craft a couple of years ago.
Latest blog entry: Ban Birds.
Nov 18, 2018, 10:49 AM
It looks like the 50, I flew the 50 and the 35, they ran great, heavy by todays standards, but long lasting industrial quality engines. I liked a 20X8 prop on the 50, larger props lugged it down and slowed down throttle response and lowered the engines performance.
Jim
Nov 18, 2018, 12:02 PM
maxray1's Avatar
Thanks guys!!!
Nov 18, 2018, 04:40 PM
Bellanca Kruesair
epoxyearl's Avatar
I had a 50 in here, and it was 'adequate' ha ha ha...
Nov 18, 2018, 05:00 PM
maxray1's Avatar
Does anyone know someone who rebuilds these?
Nov 18, 2018, 05:02 PM
"Mr. Mulligan" only requires a .60 for power! That would be fun to watch, from a safe distance.
Jim
Nov 19, 2018, 07:49 AM
Bellanca Kruesair
epoxyearl's Avatar
Jim
Recommended power was a .60, when gas engines didn't exist....Of the 500 Nosen models I've seen, none of them had a .60 !
As a rule, their size could tolerate engines in the 25-50cc ranges..The larger propellors made them good flying models, without being over-powered..
Nov 19, 2018, 08:59 AM
AMA 537620
ChillPhatCat's Avatar
I would assume nobody's trying to fly it with a .60 unless they had a gear drive. A .60 by itself can technically handle a 10 lb plane as long as the takeoff speed isn't too high.
Nov 19, 2018, 10:47 AM
Reginald's Avatar
Many years ago Dario Brisighella was the Quadra expert... still do have his book... not sure if he is still amongst us
Nov 19, 2018, 02:10 PM
Bellanca Kruesair
epoxyearl's Avatar
Dario did a couple of flywheels for me, early on....He purposely 'unbalanced' them , so the power impulses were smoothed out....and he installed the CDI ignition that replaced the ignition points and condenser...
I have a Nosen Citabria in a Museum, still with that engine. I think by now, it's 36 or 37 years old.
They're kinda like old Tractors...they deteriorate to a point, then just do whatever you ask of them.
I remember an old 'Roper' engine that someone had machined a groove into the flywheel, filled it with oil and added some loose ball bearings under the cover...Eventually the bearings would settle into a location where the engine ran fairly smoothly. Tricky !
Nov 19, 2018, 04:27 PM
Pro Hoarder
turbonut's Avatar
I have seen the ball bearing ballance rings for use on car wheel and tires..Not sure how well it worked but the principal is sound... I would think it may have problems if you changed rpm a lot
Latest blog entry: In flight
Nov 19, 2018, 05:26 PM
Bellanca Kruesair
epoxyearl's Avatar
When you first started it, it was 'out of focus'... but as the balancers found their spot the difference was noticeable....
Nov 20, 2018, 11:32 AM
maxray1's Avatar
Hmmm. Well, Maybe I'll mix up some fuel and see what happens....
I'll make a YouTube video. Thanks again guys!
Nov 20, 2018, 01:06 PM
AMA 46133
SeismicCWave's Avatar
I have done a bit of tests on a Canfield balancer. Didn't really work well.
https://www.rcgroups.com/forums/atta...mentid=5939533
Help! quadra motor cannot identify the size Hlosada Engines 15 Feb 01, 2018 05:40 PM
Sold QUADRA 35cc Two-Stroke Gas Engine w/Quadra Starter & Muffler...MAKE AN OFFER! bighank13 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 03, 2016 08:37 PM
Sold Quadra 50 & Quadra 35 Complete Engines For Parts or Repair $75.00 For Both SHIPPED!! stevster Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 18, 2015 01:20 AM
Wanted Quadra 42 and a quadra 50 linkedge540 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 23, 2014 07:34 AM
Discussion What size or model is this Quadra? admodesi Engines 5 Jul 14, 2008 02:28 AM
