Dec 24, 2018, 11:00 PM
Clancy
Clancy's Avatar
A few bare bones shots
Dec 25, 2018, 09:09 AM
Tim Cullip's Avatar
Looks like you are making good progress and it is starting to look a lot like an SE5.
Tim
Dec 28, 2018, 03:15 PM
The pin-vice has run off again
fairweatherflyer's Avatar
looking very good.
Vicky
Dec 30, 2018, 02:54 PM
Clancy
Clancy's Avatar
I will add that the plastic surface was scuffed and cleaned with alcohol before painting
Jan 02, 2019, 04:02 AM
Acorn Barnsley Bitter
Mickinsouthyorks's Avatar
Great little model
Jan 02, 2019, 12:43 PM
lovely model. Can't believe that weight - a lot let porky than the pensuti.
Looking good with the markings on.
Jan 03, 2019, 11:14 AM
Clancy
Clancy's Avatar
The Penzuti will be fine at 6 oz or a bit more. It is an IPS model. the wing span it is the same. The penzuti wings have a wider cord and there are three of them so it is just a larger model. It is not porky take that back!
Jan 03, 2019, 04:19 PM
Hi Clancy,
now I've started to cover a few peices perhaps you're right it doesn't look quite as porky after all - so I will take that back - ..Anyway your SE5 looks great
Vicky
Jan 06, 2019, 11:24 AM
Clancy
Clancy's Avatar
Here is the plane it has flown and crashed and flown again. It is light enough that little crashes do minimal damage.
I flew it 3 mph wind maybe 4 mhp tops. The rudder becomes ineffective at that much wind. So it crashed a little. latter near dusk there was no wind and it flew fine.
There is a gym with basketball courts and I will try it there.
With the lead in the front the final weight was 62 grams about 2 and 1/4 oz
Jan 22, 2019, 04:59 PM
well done. good that its flown nice looking little model. Look forward to hearing how you find flying it indoors.
must get on with the penzuti ....
Jan 26, 2019, 12:55 AM
Clancy
Clancy's Avatar
I wonder about indoor. I have flown it outdoors and I don't know if I can keep it within the size of a basketball court.
I may be a challenge.
Build Log Peter Rake Build-Off - Udet Flamingo 18" Span balticS2 Scale Kit/Scratch Built 34 Sep 21, 2019 06:36 PM
Build Log Peter Rake Scale Build-Off – 18" span Sopwith Pup Ronald L Scale Kit/Scratch Built 26 Sep 21, 2019 06:26 PM
Build Log Peter Rake Scale Build-Off - 18" Caproni-Penzuti Triplane fairweatherflyer Scale Kit/Scratch Built 142 May 18, 2019 09:00 PM
Build Log Scale Build-off 5- Peter Rake Bellanca Skyrocket Maiden Completed Patzpaint Scale Kit/Scratch Built 54 Apr 01, 2016 09:33 AM
Build Log Peter Rake’s SE5a 18” Build Shnokey Scale Kit/Scratch Built 138 Aug 18, 2015 11:10 AM
