This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Nov 15, 2018, 11:31 AM
Lithium Member
Herb's Avatar
Build Log
Freewing F-5 Tiger II 80mm EDF
I ordered this one from MRC as a pnp set (since they were out of Arf+'s),
https://www.motionrc.com/products/fr...mm-edf-jet-pnp
http://sz-freewing.com/productlist.aspx?t1=2&t2=26
https://www.motionrc.eu/products/fre...mm-edf-jet-pnp
https://www.rc-castle.com/index.php?...DESC&limit=100
http://www.hebu-shop.ch/product_info...4oc340pfau0ad4
I prefer the Swiss airforce "Patrouille Suisse" one because of better visibility.
Here is a useful link to the specs on the original one :
https://en.wikipedia.org/wiki/Northrop_F-5
Edit : Video added :
F-5N Tigershark 80mm by Freewing - 117mph (3 min 26 sec)
F-5N Tigershark by Freewing 80mm - Kamre 1080p video sunglasses (3 min 54 sec)
Nov 15, 2018, 11:36 AM
Lithium Member
Herb's Avatar
While in Berlin a few years ago I took a video of the original Patroullie Suisse exhibition,
Patrouille Suisse at Berlin Airshow ILA 2010 (0 min 44 sec)
Nov 15, 2018, 11:37 AM
Lithium Member
Herb's Avatar
A couple of pictures I took at the ILA in Berlin,
Nov 15, 2018, 11:41 AM
Lithium Member
Herb's Avatar
Although a somewhat older (2016) model, the Freewing EPO molding still seems pretty nice and quite smooth,
Nov 15, 2018, 11:46 AM
Lithium Member
Herb's Avatar
When adjusting for travel, the flaps need to be moved up all the way, so they "lock" properly and don't cause flutter
The Full Flying elevator linkage was stiffened with aluminum tubing (did not have the right carbon rod size).
Nov 15, 2018, 11:52 AM
Lithium Member
Herb's Avatar
The stock outrunner metal fan was removed, and replaced by a lighter and more efficient FMS inrunner fan,
https://www.rcgroups.com/forums/show...EDF-fan&pp=100
The stock ESC (Hobbywing 80A) was retained for now (a 100A one is on its way) and re-programmed, it now pulls ~1900W at ~83A.
Nov 15, 2018, 11:57 AM
Lithium Member
Herb's Avatar
A view of the bifurcated outlet, and front inlets. They are far from perfect but should work ok ...
Nov 15, 2018, 11:59 AM
Lithium Member
Herb's Avatar
I prefer to test all servos thoroughly before the maiden, and the F-5 here is no exception ...
Testing Freewing servos (0 min 9 sec)
Nov 15, 2018, 12:02 PM
Lithium Member
Herb's Avatar
Sizewise, the F-5 is actually a bit smaller than the new Freewing L-39,
Nov 17, 2018, 12:45 PM
Lithium Member
Herb's Avatar
Had the maiden on mine yesterday, plus an additional four flights
Flies pretty nicely, quite fast due to it's relatively smaller size ... I took the heavy stock outrunner metal fan out and put an FMS inrunner fan in mine.
The first few flights I kept adjusting trims, CG and the the elevator-to-flaps mixing to get it just right.
All five takeoffs were without any flaps on a ~100ft packed dirt runway.
The very first landing without flaps was pretty exciting, it really helps to have a lot of flaps on this one to slow it down. Nevertheless if you bring the nose up a lot it won't stall - and eventually slow down nicely
I like the Swiss scheme a lot, very visible under most conditions (blue sky or some clouds).
Even though it's an older Freewing model, the foam molding seems pretty good on mine. The interior ducting could use some (major) work.
Nov 20, 2018, 01:46 PM
Lithium Member
Herb's Avatar
Sitting next to the Freewing A-4 Skyhawk makes the latter look like a tugboat
Nov 21, 2018, 12:48 AM
Lithium Member
Herb's Avatar
I found a red paint that is a pretty good match to the original red, "apple barrel flag red", I had done some work on the intakes,
Nov 21, 2018, 12:49 AM
Lithium Member
Herb's Avatar
When doing a routine inspection I realized one of the servo horn screws had vibrated off in flight I guess they don't use loctite.
Nov 21, 2018, 01:14 PM
Lithium Member
Herb's Avatar
It's all metal in there, so regular (blue) loctite should work fine. I've put Loctite Hysol on mine to make sure they stay in there for a while
Dec 06, 2018, 12:04 PM
Lithium Member
Herb's Avatar
Too bad Freewing does not include wingtip missiles with the Patrouille Suisse version, I ordered a set from MRC ...
Patrouille Suisse ARMED Northrop F-5E Tiger II J-3084 J-3088 J-3089 (5 min 31 sec)
New Product Official Announcement: Freewing F-5N Tiger II 80mm Jet Alpha.MotionRC Foamy EDFs 4638 Today 01:06 PM
Discussion Freewing F-5 Tiger II 80mm EDF PnP clg0816 Foamy EDFs 2 Jul 06, 2017 12:30 PM
New Product Freewing F-5 Tiger II 80mm EDF Jet T-CAT Foamy EDFs 8 Nov 01, 2015 06:28 PM
Discussion 80mm sized quickie F-5 Tiger II Short build thread Knife Liddle Scratchbuilt EDFs 14 Nov 29, 2012 06:47 PM
