This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Nov 10, 2018, 07:02 PM
FPV addict
mlilasic's Avatar
Mini-Review
Review of Racerstar BR2207S 1600KV 2200KV 2500KV 3-6S Motors
Review of Racerstar 2207 BR2207S Green Edition 1600KV 2200KV 2500KV 3-6S Brushless Motor For RC Drone Frame - 1600KV
1600KV motors for my new 6S build came
I will be using this Sloss 7 Inch frame and these Mamba 6S F4 stack
Description:
Brand: Racerstar
Item name: Green Edition BR2207S brushless motor
RPM/V: optional 1600KV / 2200KV / 2500KV
Height: 20.5mm
Width: φ27.9mm
Shaft diameter: φ5mm
Motor mount hole size: M3
Screw thread: clockwise (CW)
Voltage: 11.1-22.2V
Battery: 3-6S lipo battery
Recommend ESC: 45A
Usage: for 200-300mm RC drone FPV racing frame kit
Weight with 7cm of 20AWG wire is
Features:
  • Stainless steel motor shaft
  • Long life Japanese NMB ball bearings
  • Oxygen free copper wire
  • CNC machined aluminum case
  • Patented balance techniques
  • Unique wiring method
In the box:
1 x Green Edition BR2207S brushless motor
4 x M3x6
4 x M3x8
Pros:
  • Price
  • Solide quality
  • Smooth
Cons:
Grab yours Racerstar BR2207S motors HERE.
Nov 10, 2018, 07:03 PM
FPV addict
mlilasic's Avatar
You will need some more stuff to fly quad like this:
(for all mentioned equipment below you can find my review HERE)
Zip Ties - https://goo.gl/SvvZTm
Threadlocker - https://goo.gl/fVRTg9
Battery:
Giant Power DINOGY MEGA GRAPHENE 2.0 1550mAh 14.8V 75C Lipo Battery - https://goo.gl/nTjGCi
or Giant Power Dinogy 1500mAh 14.8V 4S 65C LiPo Battery - https://goo.gl/AJGkYi
or 6S CNHL G+PLUS 22.2V 1500mAh 6S 100C Lipo
battery strap - https://goo.gl/YQdV7a
capacitor - http://bit.ly/2yPKgHe
Taranis Q X7 transmitter - http://goo.gl/iMrQu6 or
Taranis X9D Plus Transmitter SPECIAL EDITION - https://goo.gl/MxLKKF
Skyzone FPV googles - https://goo.gl/zXK8Zg
with ImmersionRC SpiroNet Antenna - https://goo.gl/GvZJeG
HMDVR Mini DVR - https://goo.gl/xOtjm0
ISDT Q6 Plus 300W 14A MINI Pocket Battery Balance Charger - https://goo.gl/ZhxnYQ
or
HOBBYMATE D6 DUO PRO - ACDC BATTERY CHARGER - https://goo.gl/BgEJz4
In my DIY builds I use this inexpensive gear:
32$ EPAI Metal Base Universal 4 Flexible Arms Soldering Station PCB Fixture Helping Hands
ANENG AN8002 Digital True RMS Multimeter
31$ CXG 936D EU Plug 220V 2in1 LCD Adjustable Temperature Digital Electric Solder Iron Soldering Station
or
34$ CXG US Plug 110V High Precision 936d LCD Adjustable Temperature Digital Electric Soldering Station
14$ DANIU 220V 300W DIY Electric Heat Shrink Gun Power Tool Hot Air Temperature Gun with Supporting Seat
5$ DANIU Electrical Cutting Plier Wire Cable Cutter Side Snips Flush Pliers Tool
3M Double Sided Adhesive Tape Super Sticky Acrylic Foam Sticker to secure VTX and receiver
My Review of EPAI Metal Base 4 Flexible Arms Soldering PCB Fixture Helping Hands
Nov 19, 2018, 05:48 PM
FPV addict
mlilasic's Avatar
I will be using this Sloss 7 Inch frame, MAMBA FC&ESC 6S combo and these Racerstar BR2207 1600KV motors
Other parts for the build:
RunCam Split 2S
BN-220 GPS GLONASS GPS
45$ FrSky R9M 900MHz Long Range Transmitter Module With R9 MM combo
MAMBA F405 Betaflight Flight Controller & F40 40A 2-6S DSHOT600 FPV Racing Brushless ESC
DALPROP CYCLONE T7056C 7inch 3-blade Propeller
or
Maiden test flight Runcam Split 2S - 7" Mamba Racerstar BR2207S 4S 1500mah 6 deg. C (6 min 19 sec)
Nov 21, 2018, 01:51 PM
FPV addict
mlilasic's Avatar
350g HD Split 2S LR quad
Dec 02, 2018, 05:07 PM
FPV addict
mlilasic's Avatar
PICT0008 mamba 7inch (7 min 16 sec)
Dec 03, 2018, 03:37 AM
FPV addict
mlilasic's Avatar
7min 4S 1550 mAh flight Runcam Split 2 - 7" Mamba Racerstar BR2207S (7 min 13 sec)
Discussion Racerstar BR2207S 2500KV akyros Multirotor Drone Power Systems 0 Apr 27, 2018 03:00 PM
New Product Racerstar BR2204/2205/2206 2300KV 2600KV 2200KV 2-4S Brushless Motor-----Free Review BGjim Multirotor Drone Power Systems 128 Nov 10, 2017 11:36 AM
New Product DYS Thor 2408 2200KV/2500KV 3-6S motor smg24 Multirotor Drone Power Systems 2 May 23, 2017 07:02 AM
Mini-Review Racerstar F540 & 3650 ESC/Motor Combos (review, work in progress) SoloProFan Electric Power Cars 19 Dec 07, 2016 04:45 PM
