This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Nov 10, 2018, 05:35 PM
Mini-HowTo
Flaps or flaperons for the FT Radian
I flew the old Radian in places that required confined space landings and steep approach angles. I made 12 inch long flaps and they worked but I wanted more flap area to get more lift and drag. I experimented with a segmented flap design so that the curved trailing edge could use hinges but not bind when flaps were deployed. I found a plastic tube and music wire that acts as a trailing edge coupler. Now the majority of the Radian trailing edge can be used for a flap or flaperon. Servos can be imbedded into the fuselage sides or into the wing panels. Since the FT Radian requires the light plugs be connected I think a 4 pin plug could support the positive and negative power requirements of the lights and servo. The fourth pin would be for the flaperon signal wire. Deans makes a small black or red 4 pin connector that would require soldering. Here are some pics of the flaps and a removable wing tip for a 62 inch wingspan sport wing.
I will post build pics when I start the project.
Discussion Flaperons vs Flaps + Ailerons mpikas Modeling Science 32 Jan 23, 2018 07:56 AM
Help! Flaperons with flaps 242 Electric Plane Talk 2 Jan 06, 2017 06:01 PM
Discussion Ailerons + Flaps = Flaperons on DX8 & Radian Pro s1l3ntb0b Radios 11 Mar 17, 2011 09:14 PM
Discussion Radian with flaps/ailerons or not or another plane? dirtdestroyer Electric Sailplanes 19 Mar 26, 2010 04:54 PM
Discussion flaps or flaperons schaubro Parkflyers 7 Jan 14, 2006 07:15 AM
