This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Nov 10, 2018, 04:33 PM
old4570's Avatar
Mini-Review
EF D2 Folding knife review
EF D2 sent for review by Fasttech.com
A quick note about fasttech.com .. To get the latest greatest price ( if there is a better price than quoted )
1. Add the product to the cart
2. Point the mouse to the trolley at the top bar and click view cart
3. Click have a coupon code and type map
Blade Hardness 58-59 HRC
Blade Material D2 Steel
Blade Type Drop Point
Handle Material G10
Blade Length 83 mm
Blade Width 3.3 cm
Open Length 200 mm
Product Weight 180 g
Blade Thickness 4mm
Lets get right to it shall we . The blade is bank vault tight all the way , there is literally no slop to speak off at all . The blade opens smoothly and locks tight . The edge on the blade was razor sharp as supplied , it literally shaved the hair on my arm . I ran the blade across my arm and when I looked there was a nice bundle of shaved hair sitting neatly on the blade . ( It is sharp )
I always like to do some cutting to see if the blade will hold it's edge , it's nice that a blade will take an edge . But even nicer is when the blade holds the edge . A box of stuff came this morning so I took the EF and cut the box up into lots and lots of little strips . I did as much cutting on that box as I could without cutting off one of my fingers . When I was done the blade had lost some of it's sharpness , but it still took hair off my arm .
At this point I am very impressed by the blade . At some 4mm thick , the blade does have some mass and you can feel it in the knife when you hold it . This means when you cut things you can feel the added drag from the blade thickness . Locking the blade in place is a Liner Lock as well as a pin stop on the blade to stop over travel and add strength . This has been done as there is no pin going through the scales to stop the blade in it's open position .
The size and weight of the EF make it more of a belt pouch knife than a pure pocket knife . You can really feel the knife in your pocket and I don't see it vanishing from your senses . There is a clip on the knife and it is very sturdy and tight . But it is in the wrong position for me and after playing with this knife for a few hours my palm has developed a sore spot from rubbing against the clip . ( + Cutting cardboard ) For a right handed person it should have been on the other side of the handle , but it is easy enough to remove ( which I will do ) by just undoing two screws . There is how ever no place to mount the clip on the other side though , your stuck with the clip where it is . ( Unless you remove it )
Bottom line is that there is only one thing I can harsh on with this knife and that is the clip . I am really impressed by the overall quality and build of this knife . The blade is strong / sharp and looks to hold an edge really well for a budget knife . Is the blade D2 ? , I can't say that . What I can say is that you are getting a hell of a lot of knife for $16.78 USD . I am amazed that at this price point you are getting so much knife . It was only a few years ago that you got a very average knife for less than $20 USD . But it really looks like the Chinese knife makers are taking knife making seriously now and I hope that the industry in general is making improvements .
I really want to give this knife 10 out of 10 , but the sore spot on my palm say's no . The clip is in the wrong position for me so I am knocking off half a point for that , so a very solid 9.5 out of 10 ( keeping in mind the $$ entry point of the EF D2 ) . Would I recommend this knife ? Well if they are all this good then heck yes . As a collector , I would call the EF a must have .
Update:
After sharpening the blade with some round steel rod , it looks like edge maintenance is going the be rather straight forward and relatively easy . Took maybe two minutes of work to restore the edge sharpness .
New Product Eachine EF-01 AIO 5.8G 40CH 25MW 800TVL 1/3 Cmos FPV Camera--Seeking reviewers BGjim FPV Equipment 305 Aug 15, 2018 03:50 AM
Review MultiwiiCopter Scarab Knife 270 Review Jason Cole FPV Racing 93 Nov 18, 2017 10:46 PM
Mini-Review New Eachine VR D2 Review - Diversity and DVR TheDroneZone Multirotor Drone Talk 3 Sep 21, 2016 03:57 AM
Mini-Review Eachine VR D2 - Review - Diversity Test nickburns FPV Equipment 0 Sep 15, 2016 11:03 AM
Article Hotwire Foam Factory's 24"-48" Hotwire Bow Cutter, Hot Knife & Plane Build Review 78dave Flight Accessories 20 Nov 02, 2009 05:13 PM
