This thread is privately moderated by jhamm, who may elect to delete unwanted replies.
Nov 07, 2018, 07:30 PM
Trader Rating: 43
$495.00 USD
Seller Pays Shipping
For Sale
Axial Yeti XL RTR
This is a MONSTER VEHICLE!! Runs great. Steering linkages (Integy) and Sway Bar (Hot Racing) have been upgraded along with the servo. Some extra parts included. I ran it on 2S. It is crazy on 3S!
Let me know if you have any questions.
Specs below:
This is the Electric Powered, 2.4GHz Radio Controlled, 1/8 scale
Ready to Run Yeti XL Monster Buggy from Axial.
FEATURES
Chassis: Composite plastic with integrated upper and lower aluminum
braces for greater stiffness, multiple upper link positions to
adjust anti-squat
Drive: Four wheel shaft, AR60XL solid rear axle, WB XL CVJ rear
driveshaft with captured cross pin design-no set screws to lose
Brushless Motor: Castle Creations 2200Kv, 4-pole
Receiver Box: Waterproof, integrated into bottom of chassis
Battery Trays: Two, easily accessible from sides of chassis
Radio: Tactic TTX300 2.4GHz FHSS spread spectrum 3-channel pistol
grip with steering rate, and steering and throttle end point
adjustments
Steering Servo: Tactic TSX55 metal gear, high-torque, water resistant
Electronic Speed Control: Vanguard AE-4 XL 6S/4S LiPo compatible
can be programmed manually via Castle Field Programming Card or the
or through the Castle Link software interface (optional)
Shocks: Oil-filled 16mm Big Bore, 20mm aluminum bodies, 4mm shafts
Transmission: All metal gears, single speed, full ball bearing
equipped
Differentials: CNC cut metal gears
Steering: Dual shear rack
Suspension: Front, independent, rear 4-link
Wheels: Officially licensed Raceline Monster wheels, 3.8" (96mm)
diameter
Tires: BF Goodrich Krawler T/A KX 2.9 x 7.25" (74 x 184mm)
Body: Trimmed and painted, polycarbonate interior tray with molded
driver and passenger figures, dashboard and center console detail
Warranty: One year bumper to bumper limited. Axial's warranty center
Hobby Services will repair or replace any incorrectly made part.
Proof of purchase is required for Axial to honor any warranty
claim. Axial reserves the right to change or modify this warranty
without notice. This warranty does not cover damages due to normal
wear and tear, users' failure to perform routine maintenance, user
error of assembly or installation, modifications, misuse, crash
damage, or the addition of aftermarket parts or optional parts.
Note: Purchasing products from unauthorized retailers may void the
warranty and prevent support and service.
Repair or replacement of the product by Hobby Services is the sole
and exclusive remedy for any loss or damages.
INCLUDES
RTR Yeti XL Monster Buggy with Radio System, ESC, Motor, Body,
4-Way Wrench and Instruction Manual
REQUIREMENTS
Batteries: Two 2S or 3S LiPo Packs with Dean's Ultra connector, 25C
minimum discharge rating
Battery Charger: To match selected batteries
AA Batteries: Four for transmitter
LiPo charge bag, maintenance and trail equipment
SPECIFICATIONS
Vehicle;
Length: 25.75" (654mm)
Width: 16.3" (414mm)
Height: 11.10" (282mm)
Wheelbase: 18.5" (470mm)
Ground Clearance: 2.48" (63mm)
Weight: 12.75" (5.78kg)
Body;
Length: 23.5" (597mm)
Width: 9.7" (247mm)
Height: 6.8" (173mm)
Thickness: .040" (1.02mm)
Battery Tray Dimensions;
Length: 6.89in(175mm)
Height: 1.3in (33mm)
Width: 1.7in (43mm)
Battery Tray Size: 175mm(L)x48mm(W)x30mm(H)
Thanks for looking
jhamm
Sold Axial Yeti XL RTR Ahmed_A Cars - Cars and Parts (FS/W) 0 Jun 26, 2016 10:06 PM
Sold Axial Yeti XL RTR crashnburn69 Cars - Trucks and Parts (FS/W) 0 Dec 31, 2015 02:56 PM
Sold Axial Yeti XL RTR w/ Extras Scale330l Cars - Trucks and Parts (FS/W) 0 Oct 06, 2015 08:50 PM
Sold RTR Axial Yeti XL w/Upgrades Scale330l Cars - Trucks and Parts (FS/W) 5 Sep 27, 2015 11:34 PM
Sold Axial Yeti XL Fully RTR includes lipos. 1 run old birdy233 Cars - Cars and Parts (FS/W) 0 Dec 05, 2014 10:17 PM
