Nov 06, 2018, 06:09 PM
Anyone recognize this motor.
Anyone recognize this motor. I got two of these in a lot that I recently bought.
Nov 06, 2018, 06:40 PM
Ken Myers's Avatar
It is some type of EMP but it could have been branded as several different brands. They were so, so motors. I don't know if they are still being produced.
Nov 06, 2018, 07:54 PM
scirocco's Avatar
Even without a specific ID, with the Kv and weight you have everything you need to start using it.
It will be good for at least 3W input per gram.
And it will perform fairly simarly to other motors with the same Kv and weight. You can use the motor search function in ECalc to find similar motors and that will help you to select prop and battery voltage.
If you need help with that, weigh the motor and post what you want to do with it, max diameter prop you want to run and cell count you want to use. We can find you a safe ballpark solution that you can then refine in the real world with your wattmeter
Nov 07, 2018, 05:12 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
Originally Posted by scirocco
Even without a specific ID, with the Kv and weight you have everything you need to start using it. ...
Several simple straightforward methods for determining Kv (in rpm/volt)
www.bavaria-direct.co.za
→ Motor Constants
→ The speed constant or velocity constant (Kv)
Vriendelijke groeten Ron
Discussion Anyone recognize this motor? Martin Irvine Scratchbuilt Indoor and Micro Models 11 Dec 06, 2016 10:49 PM
Help! Does anyone recognize this model? iflyfloats Giant Scale Airplanes 11 Jan 31, 2016 09:26 AM
Question Anyone recognize this oldie? orbsah Fuel Plane Talk 4 Dec 15, 2015 06:01 PM
Question Does anyone recognize this old F3B winch? Bob McGowan Multi Task F3X 35 Nov 09, 2015 08:33 PM
Discussion Anyone recognize this boat????? builts10 Dock Talk 1 Oct 01, 2015 03:12 PM
